Intel® C++ Compiler
7875 Discussions
(c++11) is_trivially_copy_constructible always false if class has destructor
Andrey_K_
Hi, when some class (T) has destructor is_trivially_copy_constructible<T>::value is always false.
For example:
//trivially copy constructable class with destructor
class CSomeClass {
public:
	int x;
	//explicitly specify default copy constructor
	CSomeClass(const CSomeClass&) = default;
	//non-default destructor
	~CSomeClass(){
//all asserts below are failed
static_assert(is_trivially_copy_constructible<CSomeClass>::value, "not a trivially copy constructable");
static_assert(is_trivially_move_constructible<CSomeClass>::value, "not a trivially move constructable");
static_assert(is_trivially_constructible<CSomeClass, const CSomeClass&>::value,  "not a trivially copy constructable");
static_assert(is_trivially_constructible<CSomeClass, CSomeClass&&>::value, "not a trivially copy constructable");
If we remove destructor, all assertion will pass.
According C++11 specification (in my case I refer to draft n3376), is_trivially_copy_constructible<T> should be true when is_copy_constructible<T> is true and only trivial operations are involved.
So I think is_trivially_copy_constructible should be true in the above example.
I have installed the following compiler: Intel® C++ Composer XE 2015   Package ID : w_ccompxe_2015.0.030, for Microsoft* Visual Studio* 2013.
Btw, with ms vc120 compiler, all asserts are pass.
Shenghong_G_Intel
Hi Andrey,
I can reproduce the issue, I will track the issue in our problem tracking system. Hope to see it fixed (implemented) in future.
Note: This C++11 feature is even not supported by latest gcc 4.9.0 and ICC 15.0 Linux version.
Shenghong
Shenghong_G_Intel
Hi Andrey,
Shenghong
