Intel® C++ Compiler
7873 Discussions
(c++11) issues with using pointer to local function as template argument
Andrey_K_
Trying to compile the following code:
#include <iostream>
using namespace std;
template<void (*F)()> void SetCallback(){
	F();
static void Foo() {
	struct stub_t {
		static void cb(){
			cout << "Foo::stub_t::cb()" << endl;
	SetCallback<&stub_t::cb>();
void TemplateInstantiation() {
	Foo();
I get this error: "(18): error : a template argument may not reference a non-external entity".
But I can't find any restrictions on template arguments in c++11 specification, at least in draft n3376, that can explain why this is wrong.
Is there something that I have been missed? Or this is specific of the compiler?
I'm using Intel® C++ Composer XE 2015.
Judith_W_Intel
I take that back... Actually it looks like Microsoft has always allowed it (even before it was legal).
I have entered a defect (DPD200256284) for us to change our compiler to allow this. Thanks for reporting it.
Judy
Judith_W_Intel
Yes it looks like this was changed between C++03 and C++11 -- see discussion here:
http://stackoverflow.com/questions/14597463/why-did-c03-require-template-parameters-to-have-external-linkage
It looks like no compiler (including the most recent releases of Clang, GNU, Microsoft and our compiler) has implemented this change yet.
Judy
Judith_W_Intel
Judy
J_B_
Anyway (like a compiler option) to circumvent this in the meantime without a code rewrite?
