Hi.
We got customer using c++ 9.1.042-1 on rhel 4.6 .
We want to upgrade to rhel 5.3.
Does the compiler & flexlm will continue working ??
regards
Shalom.
There's not enough information to answer about C++, except that you will be outside the range of supported configurations. The most likely problem would be with the g++ on el 5, although old, still being newer than any available when icpc 9.1 was developed. That might be dealt with by installing a g++ in the range supported by your icpc.
I don't think you should have difficulty with flexlm.
