When I compile the following hello world code using icpc on Mac OS X 10.9
#include<iostream>
using namespace std;
int main()
cout<<"Hello World!"<<endl;
return 0;
I get the following error message:
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/5.1/include/stddef.h(29): error: expression preceding parentheses of apparent call must have (pointer-to-) function type
#if !defined(_PTRDIFF_T) || __has_feature(modules)
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/5.1/include/stddef.h(31): error: function call is not allowed in a constant expression
#if !__has_feature(modules)
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/5.1/include/stddef.h(37): error: function call is not allowed in a constant expression
#if !defined(_SIZE_T) || __has_feature(modules)
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/5.1/include/stddef.h(48): error: expression preceding parentheses of apparent call must have (pointer-to-) function type
!defined(_RSIZE_T)) || __has_feature(modules)
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/5.1/include/stddef.h(50): error: function call is not allowed in a constant expression
The version I used is Intel Composer XE 13.0.3 20130606.
Hi Hongxuan,
Apple constantly develops OS X libraries, sometimes introducing changes that make them incompatible with older compilers (both icc and clang). We update icc to make it compatible with new OS X / XCode releases, but we do so for currently supported versions only -- which is 14.0 at the moment.
If you want to continue to use icc 13.0, you have to use older OS X / XCode. If you want to switch to OS X 10.9 / XCode 5.1, you have to upgrade to icc 14.0 (or 15.0, which is currently in beta). Sorry if this is a disappointing answer...
Andrey
To clarify, by "supported" I mean "supported on the latest OS X / XCode releases". For OS X 10.9 / XCode 5.x this is 14.0 only. We continue to support 13.0 on older OSes / XCodes.
Andrey
Thanks. Where I can find the 14.0 version. The latest version I can see now is 2013_sp1.2.139.
Andrey Bokhanko (Intel) wrote:
Hi Hongxuan,
Andrey
That is the right version. You may download it from Intel Registration and Download Center link https://registrationcenter.intel.com/RegCenter/Register.aspx.
Om
The latest Intel compiler 15.0 supports Xcode 5.0 and 5.1. The release version of compiler is available for download from Intel Registration and download center.
Om
