I am trying to use the last version of Intel compiler to build the last version of cmake on Debian9. Getting stuck on this: export CC=icc export CFLAGS="-fPIC -msse4.1 -axAVX,CORE-AVX2" export CXX=icpc export CXXFLAGS="-fPIC -msse4.1 -axAVX,CORE-AVX2" ./configure --verbose make [ 68%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmQtAutoGeneratorMocUic.cxx.o cd /scratch/cmake-3.14.5/Source && /software/intel-parallel-studio/cluster.2019.4/intel-19.0.4/compilers_and_libraries_2019.4.243/linux/bin/intel64/icpc -DCMAKE_BUILD_WITH_CMAKE -DCURL_STATICLIB -DLIBARCHIVE_STATIC -I/scratch/cmake-3.14.5/Utilities -I/scratch/cmake-3.14.5/Source -I/scratch/cmake-3.14.5/Source/LexerParser -I/scratch/cmake-3.14.5/Utilities/cmcompress -I/scratch/cmake-3.14.5/Source/CTest -I/scratch/cmake-3.14.5/Source/CPack -fPIC -msse4.1 -axAVX,CORE-AVX2 -std=gnu++17 -o CMakeFiles/CMakeLib.dir/cmQtAutoGeneratorMocUic.cxx.o -c /scratch/cmake-3.14.5/Source/cmQtAutoGeneratorMocUic.cxx /scratch/cmake-3.14.5/Source/cmOrderDirectories.cxx(430): remark #15009: _ZN18cmOrderDirectories13FindConflictsEv has been targeted for automatic cpu dispatch /usr/include/c++/6.3.0/bits/stl_algo.h(1839): remark #15009: ZSt16__insertion_sortIN9__gnu_cxx17__normal_iteratorIPSt4pairIiiESt6vectorIS3_SaIS3_EEEENS0_5__ops15_Iter_less_iterEEvT_SB_T0 has been targeted for automatic cpu dispatch /usr/include/c++/6.3.0/bits/stl_algobase.h(750): remark #15009: ZSt10__fill_n_aIPcmiEN9__gnu_cxx11__enable_ifIXsr3std11__is_scalarIT1_EE7__valueET_E6__typeES4_T0_RKS3 has been targeted for automatic cpu dispatch /usr/include/c++/6.3.0/type_traits(2505): error: class "std::__result_of_impl<false, false, std::_Mem_fn<void (cmQtAutoGeneratorMocUic::WorkerT::*)()>, cmQtAutoGeneratorMocUic::WorkerT *>" has no member class "type"
When I remove the -std=gnu++17 directive the compilation goes without error. Is this the bug of the compiler or the code?
Thank you, Petr
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Neither one. C++17 doesn't allow class w/o member class "type"
Thank you Viet,
so it looks like a configuration problem to avoid compiling this file with gnu++17 directive. However I tried to build it once again on system with newer gcc and it passed ok. Why Icc depends on gcc in some way as is mentioned in the error log?
