I've tried about six times now to post a message on this forum - and my posts just vanish - whats up?
It would appear that when I paste a copy of a compiler message the post just vanishes.
Any idea why?
I can see this posting fine.
do you mean you're trying to paste some code and code disappeared?
When pasting code, the code with "".
Jennifer
I find that trying to include a copy of an error message generated by the compiler and the code that causes it, makes the posts to vanish.
Including...
1>\suite\programs\nex2\imaginfo.h(33): error: DestructElements is not a template
works
but adding the next line from the compiler output causes the post to vanish
Looks like a bad return from ping.chartbeat.net
Quoting it maks no difference.
My response got cut off when trying to use '<' & '>'.
But those characters will only affect the final text, it should not cause the whole posting vanish.
could you attach thescreen-capture of the compiler output to this thread? so we can find out what might be causing the issue.Thank you very much,
Jennifer
hope you can see this...
including the line starting with Template seems to cause the problem
Thanks Jim!
I'll let the engineers know about this. Sorry for the inconvinience!
Jennifer
