Dear Experts,
I have recently downloaded and installed the "Intel(R) Parallel Studio XE 2018 Update 1" which seems to lack "stdio.h"?
For example, if i try to initiate the env with "psxevars.bat intel64", it shows no error:
Copyright (C) 2017 Intel Corporation. All rights reserved.
Intel(R) Compiler 18.0 Update 1 (package 156)
** Visual Studio 2017 Developer Command Prompt v15.5.7
** Copyright (c) 2017 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
however if i try to build some program, for example https://software.intel.com/sites/default/files/openmp_samples_C_win_20170912.zip , it fails with following message:
C:\Users\animeshs\Desktop\openmp_samples>build
icl /nologo /O2 /Qstd=c99 /Qopenmp /F256000000 /Forelease\ src\openmp_sample.c /link /INCREMENTAL:NO /SUBSYSTEM:CONSOLE /MANIFEST:NO /out:release\openmp_sample.exe
openmp_sample.c
src\openmp_sample.c(54): catastrophic error: cannot open source file "stdio.h"
#include <stdio.h>
compilation aborted for src\openmp_sample.c (code 4)
Any ideas on how to proceed?
Ani
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
That's one of many include and library files which ICL inherits from Microsoft CL and SDK. As the .bat file which sets up ICL also sets up CL, as shown by your echo of vcvarsall.bat, you should also be able to build with CL (if your sample doesn't depend too much on C99 or OpenMP beyond 2.0 and you stick with CL command line options). In VS2017 install, you must install C++ and appropriate SDK choice. If you need to go back and update those, you will likely need to reinstall (not simply repair) ICL.
Thanks Tim, reinstalling the VS2017 worked! However i am wondering if VS is needed at all to compile a MPI based C++ program?
The program compiles flawlessly on the Linux systems with GCC/MPI but i am not able to do same using Intel on Windows. The compile documents plainly mentioned to use icpc https://github.com/sebhtml/ray/blob/master/Documentation/COMPILERS.txt , any ideas on how to proceed on this one?
Dear expert,
I have same issue to install CNS_solve on MacOS Mojave, as "catastrophic error: cannot open source file "stdio.h"" the scripts as followed:
Using Makefile template for compiler: ifort
removing old source files
linking source files to mac-intel-darwin/source
linking machine_f.f to source directory
linking machine_c.c to source directory
linking generic fft file to source directory
making Makefile in source directory
testing Fortran and C compilers
compiling: icc -O -axSSSE3 -DINTEGER='long int' -DCNS_ARCH_TYPE_LINUX
test_c.c(1): catastrophic error: cannot open source file "stdio.h"
#include <stdio.h>
compilation aborted for test_c.c (code 4)
/bin/sh: ./test_c: No such file or directory
***** ERROR: problem with C compiler *****
make[3]: *** [c-test] Error 3
compiling: ifort -i8 -traceback -w -vec-report0 -O -axSSSE3
linking: ifort -static-intel -save-temps -traceback -O -axPT
ifort: command line remark #10279: option '-axP' is deprecated and will be removed in a future release. See '-help deprecated'
ifort: command line warning #10150: option '-axT' not supported
Fortran compiler passes test
making utility programs
make relink
make default
ifort -o PSmapx -O -xP -w -vec-report0 PSmapx.f -i-static
ifort -o PSmapy -O -xP -w -vec-report0 PSmapy.f -i-static
ifort -o PSmapz -O -xP -w -vec-report0 PSmapz.f -i-static
icc -o to_cns -O to_cns.c -lm
to_cns.c(11): catastrophic error: cannot open source file "stdio.h"
#include <stdio.h>
compilation aborted for to_cns.c (code 4)
make[4]: *** [to_cns] Error 4
make[3]: *** [utils] Error 2
make[2]: *** [compile-utils] Error 2
make[1]: *** [utils] Error 2
flags:
fortran -> [ifort] -i8 -traceback -w -vec-report0 -O -axSSSE3
c -> [icc] -O -axSSSE3 -DINTEGER='long int' -DCNS_ARCH_TYPE_LINUX
link -> [ifort] -static-intel -save-temps -traceback -O -axPT
Any suggestion,
Best regards
Does it work with gcc?
