I've built clapack (http://www.netlib.org/clapack/) with ICC.
When I try to compile a simple program with clapack libs (blas_INTEL_LINUX.a, lapack_INTEL_LINUX.a), I recieve an error:
> icc -I/home/gordon/intel_clapack_C/CLAPACK-3.2.1/INCLUDE -L/home/gordon/intel_clapack_C/CLAPACK-3.2.1 /home/gordon/intel_clapack_C/CLAPACK-3.2.1/lapack_INTEL_LINUX.a /home/gordon/intel_clapack_C/CLAPACK-3.2.1/blas_INTEL_LINUX.a lapacktest.cpp
/tmp/iccfAlaCq.o: In function `main':
lapacktest.cpp:(.text+0x40): undefined reference to `cgeev_'
program (lapacktest.cpp):
#include
#include
extern "C"{
#include
int main(){
printf("\\n\\nhello world!!!\\n\\n");
cgeev_(NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL);
return 0;
Can you help me to find the reason of this error?
PS:cgeev_ is definitely in lapack_INTEL_LINUX.a
>nm lapack_INTEL_LINUX.a |grep cgeev
cgeev.o:
00000000 T cgeev_
cgeevx.o:
00000000 T cgeevx_
Help me please!
Unless you don't have Intel's MKL installed (it is usually distributed now with ICC), or have some other good reason to use the slower reference Lapack sources from Netlib, the following will be simpler:
Remove the '#include' line
Replace '' by ''
Compile with the command
icc -mkl lapacktest.cpp
You may now run the a.out, and your second greeting (after 'hello world!') will be a Segmentation fault, since you are calling cgeev_ with all NULL arguments.
Replace '
Thanks, mecej4
But what do you mean that MKLis usually distributed now with ICC?
I've compiled with lapacktest.cpp withsuccessfully, but when I ran my a.out, I have an error, that shared library libmkl_intel.so not found.
./a.out: error while loading shared libraries: libmkl_intel.so: cannot open shared object file: No such file or directory
The reason why I tried to use netlib clapack instead of MKL was that I have no license for MKL.
I've installed non-commercial MKL for linux and now it works!
Thanks a lot!
