Is there a way to enable color diagnostics in icc like the one available in gcc 4.9 and later or clang?
http://clang.llvm.org/diagnostics.html
https://gcc.gnu.org/gcc-4.9/changes.html
https://i.stack.imgur.com/lqGAH.png
I am using icc (ICC) 17.0.1 20161005
No sorry the Intel compiler does not have this functionality.
Thank you for the answer. Maybe you can add it to the wish list, as the other compilers have it for some time.
Sometimes it is hard to find the error among many warnings, and having to cut & paste compiler diagnostics in editor, so I can search for the error is not very comfortable. If we had color diagnostics, the errors would immediately stand out.
I seem to recall seeing this capability in the DEC VAX compilers more than 20 years ago....
You might be able to get some of the desired functionality from a colorizing version of grep. Getting multiple colors for different messages is slightly convoluted, but not particularly hard to script. Some potentially helpful references:
Thanks for the reply, John and Sergey. I am "old school" and compile from console on Linux.
My editor (nedit) does color syntax highlighting, "ls" is in color by file type, only intel c compiler stays monochrome ;-(
I was asking because due to high number of options, I was afraid I was overlooking the possibility of colorized diagnostics.
I think this option is relatively simple to implement, if we compare it to automatic vectorization and other advanced optimizations.
As a solution: you can fix warnings. Writing code without warnings is a good practice.
That is what I try to do. But things are so complex that at a certain warning level you will always get something, like -Wall or -Wp64
And I don't always compile only my own code; i compile third party projects and libraries, which I don't have time to maintain; I only need to make them compile and work with minimum changes. It could be old code which does not respect current guidelines in software engineering.
I would also vote to have coloured output of Intel compilers (i.e. general colouring to help human reading of the output and also for all of the compilers, i.e. C/C++ and Fortran). It would help visual identification and improve productivity.
Thanks, FI
Sergey Kostrov wrote:
>>...As a solution: you can fix warnings. Writing code without warnings is a good practice.
It is a good recommendation for "toy" software projects. In a real life, as dpeterc mentioned, things are more-more complex.
I'm understand that it is very hard for big projects. But it is a requirement if you need a safe code, for example in network or security modules.
In a company where I'm work (http://www.radmin.com/) 0 warnings is a requirement for all code (exclude third party libraries) and this is a real life and not a "toy" projects. For example in my own "toy" projects with 3d graphics (part of them listed here) when I fix all warnings was fixed a bug with camera jerking.
And I'm agree that colorized diagnostics is a good feature.
