I am trying to use the Intel math library, and I get about compatibilty with math.h. I understand these libraries cannot be compatible. My problem is that I am linking with some external library and the include file contains reference to math.h. Is there any simple way to solve this issue? I dont have the source code of the external library.
Marc
Marc
It seems that you should be using
It's doable.
You can set the compiler on file-bases. So you can set the compiler to "VC" if it uses "math.h". And do not use "/Zl" option(omit default library name in .OBJ).
When it comes to distribute, you'll need to package both VC and IC's math libs.
