Intel® C++ Compiler
compilation error regarding cmath
Ctech_Ctech
Hi All,
I am trying to compile my C++ application using icc.
However, I get the following error:
icc -g -fPIC -O2 -c -I ./incFolder -o myapp.o myapp.cpp
/usr/include/c++/4.4.1/cmath(500): error: identifier "__builtin_fpclassify" is undefined
return __builtin_fpclassify(FP_NAN, FP_INFINITE, FP_NORMAL,
detected during:
instantiation of "__gnu_cxx::__enable_if<:__IS_ARITHMETIC><_Tp>::__value, int>::__type std::fpclassify(_Tp) [with _Tp=float]" at line 65 of "/usr/include/boost/functional/hash/detail/hash_float.hpp"
instantiation of "size_t={unsigned long} boost::hash_detail::float_hash_value(T) [with T=float]" at line 282 of "/usr/include/boost/functional/hash/hash.hpp"
detected during:
instantiation of "__gnu_cxx::__enable_if<:__IS_ARITHMETIC><_Tp>::__value, int>::__type std::fpclassify(_Tp) [with _Tp=long double]" at line 65 of "/usr/include/boost/functional/hash/detail/hash_float.hpp"
instantiation of "size_t={unsigned long} boost::hash_detail::float_hash_value(T) [with T=long double]" at line 292 of "/usr/include/boost/functional/hash/hash.hpp"
compilation aborted for myapp.cpp (code 2)
By the way, I do not get this error when compiling my application using gcc.
How can I resolve it ?
Milind_Kulkarni__Int
New Contributor II
This is a known problem with many new builtin functions that are provided in new versions of g++.
For a relevant issue in Intel Software Network, please visit this link:--
http://software.intel.com/en-us/forums/intel-c-compiler/topic/64188/
Following workarounds:--
1) If you try with g++ 4.3.2 and earlier, this error would not come.
current icpc supports g++ 4.2.1 headers, but probably not current g++. Due to the great divergence between C99 and C++, I suppose it's difficult to tie down all the loose ends.
Also check this link:--
http://gcc.gnu.org/onlinedocs/gcc/Other-Builtins.html
indicates that the treatment of built-ins should depend on -std= setting. icc supports only a minimal subset of the gcc -std= options (not, for example, the -std=gnuxx), and those not apparently in accordance with gcc documentation on built-ins.
2) You can as well try to use intel hearder instead of , and see whether this works, because it worked for me for a few cases including this.
Also, this has already been raised as a bug, and was supposed to be fixed in latest 11.1, though I do not know why this still is not.
