Hi all,
I am trying to compile my sse2 code unders Visual studio 2010 and Intel Parallel Composer 2011
My runtime library is MultiThreaded dll and my Os is windows 7 64 bits.
When I compile, I have many double definitions with emmintrin.h and winnt.h with _mm_pause symbol for exemple.
I have too a warning on the dvec.h file, on a "#pragma pack(push,32)" line, because the value cannot be 32 but only , 1,2,4,8,16. It is strange because it is a intel file.
And I have a conflict between intel files (like emmintrin.h) et visual studio files (like intrin.h)
I thought that if I use the Intel platform toolset, I disable the equivalent file on the visual studio environment.
Results, I compile without error on Platform Toolset v90,v100, Windows7.1SDK but not with the Intel Parallel Composer 2011.
It would be nice if you can share the test case. It will help in narrowing down the issue.
Topic Options
