Intel® C++ Compiler
compilation errors
Sharon_B_
Using icc v 15.0.1, I get the errors listed below when compiling the following nested for loops. gcc does not complain. What flags
should be used to "ignore" the errors, or recommend changes to the sources?
#pragma omp parallel for
  for ( size_t K = 0; K < Nseg; ++K ) {
    for ( size_t X = 0; X < numDet; ++X ) {
      for ( size_t n = 0; n < intN; ++n ) {
Compile time errors are as follows:
 foo.c(100): error: "K" can only appear on one data scope attribute clause inan OpenMP pragma (except firstprivate and lastprivate)
foo.c(100): error: "X" can only appear on one data scope attribute clause in an OpenMP pragma (except firstprivate and lastprivate)
  ^compilation aborted for foo.c (code 2)
thanks!
jimdempseyatthecove
Black Belt
What your program is directing the compiler and OpenMP runtime to do is:
a) break the iteration space (0,Nseg] into available number of logical processor number (or less) pieces and allocate each piece to each thread. Note this is the outer for loop.
b) For each thread, and provided nested parallelism is enabled, break the iteration space (0,numDet] into available number of logical processor number (or less) pieces and allocate each piece to each thread. Note, this is the middle loop *** for each thread of the outer loop. IOW, if nested parallelism is enabled, this will require nThreads * nThreads number of threads. Additionally, the error message relates to the outer scoped K not being declared firstprivate.
c) Fore each thread * thread, and provided nested parallelism is enabled, break the iteration space (0,intN] into available number of logical processor number (or less) pieces and allocate each piece to each thread of each thread. Note, this is the middle loop *** for each thread of the outer loop * each thread of the middle loop. IOW, if nested parallelism is enabled, this will require nThreads * nThreads * nThreads number of threads. Additionally, the error message relates to the outer scoped K and middle scoped X not being declared firstprivate.
Jim Dempsey
