Histruct ksllt{int a;int b;};typedef struct ksllt ksllt;typedef int sword;
#define KSLLATDW(name, descrip, cleanup, level, wtcls) \\ KSLLATDV(name, descrip, cleanup, level) \\ KSLEVTDX3(name##lf_, "latch: " descrip, "address", "number", \\ "tries", 0, 0, wtcls)
#define KSLLATDV(name, descrip, cleanup, level) KSMSGADV(ksllt, name)
#define KSLEVTDX3(name, descrip, p1text, p2text, p3text,flags,callbacks,cls) \\ KSLEVTDV(name, descrip, p1text, p2text, p3text, flags, callbacks, cls,\\ descrip)
#define KSLEVTDV(name, descrip, p1text, p2text, p3text, flags, callbacks, \\ cls, display_name) \\ KSMSGADV(sword, name)
#define KSMSGADV(type,name) extern type name;KSLLATDW(ksmsal_, "ksm", 0, 0, 0)main(){
printf("done.\\n");}
I donno why compilation is failing in 2nd case.
command to compile
icl /c /FI:stubksm6888.h try.c
icl /c /FI:stubksm6888.h try2.c
case 1
#include
struct ksllt
int a;
int b;
typedef int sword;
descrip)
main()
printf("done.\\n");
#include #define KSLLATDW(name, descrip, cleanup, level, wtcls) \\ KSLLATDV(name, descrip, cleanup, level) \\ KSLEVTDX3(name##lf_, "latch: " descrip, "address", "number", \\ "tries", 0, 0, wtcls)
case 2
#include
struct ksllt
int a;
int b;
typedef int sword;
KSLLATDW2(name, descrip, cleanup, level, wtcls, descrip)
#define KSLLATDW2(name, descrip, cleanup, level, wtcls, display_name) \\
KSLLATDV2(name, descrip, cleanup, level, display_name) \\
KSLEVTDY3(name##lf_, "latch: " descrip, "address", "number", \\
"tries", 0, 0, wtcls, "latch: " display_name)
#define KSLLATDV2(name, descrip, cleanup, level, display_name) \\
#define KSLEVTDY3(name, descrip, p1text, p2text, p3text, \\
flags, callbacks, cls, display_name) \\
KSLEVTDV(name, descrip, p1text, p2text, p3text, \\
main()
printf("Done.\\n");
stubksm6888.h
#define ksmsal_ (*ksmsal_)
does "cl" compile ok?
Jennifer
It's not possible to save from this screen without incurring additional formatting errors. Correcting formatting errors allows compilation. So I suspect some of the apparent formatting errors are in your source, and more were introduced as you pasted to the screen.
