Intel® C++ Compiler
compiling gsl 1.15 with intel 11.1
afylot1
I am trying to compile gsl 1.15 with intel 11.1
I tried the optimization stated in
http://software.intel.com/en-us/forums/showthread.php?t=75549
CFLAGS="-O2 -m64 -march=core2 -mtune=core2 -Wpointer-arith -fno-strict-aliasing "
but I found that the test fails in specfunc
make[2]: Entering directory `/my/path/gsl-1.15/specfunc'
/bin/sh: line 5: 11112 Illegal instruction (core dumped) ${dir}$tst
FAIL: test
1 of 1 test failed
any ideas?
TimP
Black Belt
There's little point in setting -march or -mtune to core2 for x86_64, even in gcc. The defaults (compatibility with nocona and opteron) are fine. mtune is redundant, once march is set to the same value. Does icc work when those options are omitted?
For complex numbers, gsl uses local struct definitions, which are unlikely to be recognized by compilers as optimizable by -msse3.
Perhaps this unusual combination of options is misinterpreted by icc. -march=core2 would imply -mssse3.
It might be safer to add -msse3 to the option list rather than depending on various compilers to set architecture by -march=core2. Recent production core 2 CPUs support also -msse4.1, but early ones (like mine) don't. It should be safe to set -xssse3 if you want code which is compatible with all Core2 CPUs but not with AMD.
Georg_Z_Intel
what processors are you compiling & running the test on? Illegal instruction sounds like optimizing for a processor generation newer than the one you actually use.
Georg Zitzlsberger
TimP
Black Belt
afylot1
I am compiling on
Intel Xeon CPU 3.00GHz
Georg_Z_Intel
I'm sorry, but that's not enough information. We've lots of generations of Intel Xeon CPUs with 3GHz. Some are far pre-core2 era.
On Linux* you can do a
$ cat /proc/cpuinfo
or look up your processor in our products database here:
http://ark.intel.com/
and send us the link.
Georg Zitzlsberger
afylot1
processor : 0
vendor_id : GenuineIntel
cpu family : 15
model : 4
model name : Intel Xeon CPU 3.00GHz
stepping : 3
cpu MHz : 3000.000
cache size : 2048 KB
physical id : 0
siblings : 1
core id : 0
cpu cores : 1
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx lm constant_tsc pebs bts pni dtes64 monitor ds_cpl cid cx16 xtpr
bogomips : 5985.01
clflush size : 64
cache_alignment : 128
address sizes : 36 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 15
model : 4
stepping : 3
cpu MHz : 3000.000
physical id : 3
siblings : 1
core id : 0
cpu cores : 1
apicid : 6
initial apicid : 6
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
bogomips : 5985.25
clflush size : 64
power management:
afylot1
Quoting TimP (Intel)
I removed mtune and mcore and it worked, now I am compiling it with -xsse3, just to test.
By the way, do you think it is possible to have a more aggressive optimization?
EDIT
-xsse3 works
TimP
Black Belt
The most obvious more aggressive compiler option would be -O3, which may give you optimizations on nested loops, but it's not out of the question that you may not find any way to improve performance, even if you have a meaningful measurement. Your CPU appears to be one which doesn't support SSE4.1; besides, I've run into several cases where compiling for that architecture reduced performance, even though the CPU supported it.
