Intel® C++ Compiler
7956 Discussions
composerxe-2011 update 6 internal error
Mike_Glass
Using the composer_xe_2011_sp1.6.233 C++ compiler on the following code snippet gives an internal error
const double** GetGaussPnts() {
static const double xi = 0.5;
static const double *pxi = ξ
return &pxi;
$ icpc -c -o zsal.o zsal.C
(0): internal error: backend signals
compilation aborted for zsal.C (code 4)
We have been able to compile this code that this snippet came from with Intel 11.1 and 12.0 compilers along with gnu, pgi, pathscale, and xlc compilers.
JenniferJ
This is a compiler bug as well. I'll report it right now.
One workaround is to move the "xi" static const to the global space.
Another workaround is to use "-O0" for this one file.
Jennifer
Mike_Glass
FYI, I also tried compiling this with composerxe-2011 update 7 and got the same error.
SergeyKostrov
Valued Contributor II
Verified compilation for all C/C++ compilers integrated into our Build Environment for Desktop & Embedded Platforms:
- MS C/C++ compiler ( VS 2005 \ VS 2008 \ VS 2010 )- Pass
- MinGW v3.4.2 compiler- Pass
- Borland C/C++ v5.5 compiler- Pass
- Turbo C/C++ v3.1compiler - Pass
- Turbo C v1.01 compiler - Pass
JenniferJ
This issue has been fixed in the update9 or newer. You can download it from the registration center.
thanks,
Jennifer
SergeyKostrov
This issue has been fixed in the update9 or newer...
I would like to confirm that the problem is resolved and my old Test-Case is working properly. A screenshot is ensclosed:
Sergey
