Intel® C++ Compiler
7833 Discussions
constexpr bug with c++ compiler version 15
rnickb
The following code compiles fine with clang and gcc but gives this error with icc:
icc -std=c++11 problem.cpp
problem.cpp(12): error: expression must have a constant value
    , typename std::enable_if<MyCheck<T>{}>::type
compilation aborted for problem.cpp (code 2)
#include <type_traits>
template<class T>
struct MyCheck {
  constexpr operator bool() const {
    return sizeof(T) > sizeof(int);
template<
    class T
  , typename std::enable_if<MyCheck<T>{}, int>::type
void f() {
int main() {
  return 0;
rnickb
also added as attachment
Feilong_H_Intel
Hi rnickb,
Thank you for your test case.  I've produced the error on my machine.  I'm entering it to our problem-tracking database.  Engineering team will look into it soon.
Feilong_H_Intel
Hi rnickb,
This issue has been resolved in 16.0 compiler.  FYI.
