When compiling the attached program with
icc -O3 -fp-model fast=2 -xCORE-AVX2 -fma -c -S mandel_cilk.cpp
I get ": internal error: 20000_3650". From https://software.intel.com/en-us/forums/topic/505663?language=it, it looks like this means there was a crash with the compiler.
Thanks for reporting your issue. I have escalated this issue to development team, I will check status and keep update you.
Reddy
This issue can be worked around by removing the temporary array "test", which may also speed up the code:
for(int k=0; k<max_count; ++k) {
int rez = __sec_reduce_add(abs(z[:]) < 2.0f);
if (!rez)
Reddy
