Intel® C++ Compiler
7953 Discussions
cross compile with intel C++ compiler for linux
apfelboeck
Is it possible to compile on a intel based computer (i.e. i64) that running linux, code for a sh4,arm,mips based target that also running linux, by using the intel compiler?
Om_S_Intel
The Intel compiler generates code only for Intel processors or compatible processors.
Om_S_Intel
mechanize
is it possible then to cross compile to make apps for an ia64 while working on an intel64 machine?
TimP
Quoting - mechanize
Not with Intel compilers, except in the mode where you make a 32-bit application and run under the old EL emulator on ia64.
mechanize
Thank you!
