Visual Studio 2010, Intel Compiler version 12.1.4.122.
This problem occurs in debug builds.
If /debug:parallel is set, pdbxinst.lib is included. It has a defaultlib directive pointing to libcpmt. If any module compiled with _DEBUG set uses libcpmt, a LNK2038 error results for _ITERATOR_DEBUG_LEVEL.
The workaround of /NODEFAULTLIB:libcpmt.lib when linkingseems to work, but has unknown side effects.
Either a debug version of pdbxinst.lib that links to libcpmtd.lib should be supplied and used in this case, or the dependency on libcpmt needs removing.
Orin
Orin,
What's the reason for building with /debug:parallel? This option is for creating parallel debug checks used by the Intel Parallel Debugger Extension to detect data sharing events in OpenMP* parallelized code.
Same as: http://software.intel.com/en-us/forums/showthread.php?t=105411
Regards, Hubert.
My code is using OpenMP. I have /Qopenmp set too. I was chasing a memory overwrite problem and trying to make sure it wasn't hapenning in my code.
Orin.
As said, /debug:parallel is for data sharing detection of multithreaded OpenMP code only. So even if you are debugging OpenMP you don't necessarily need /debug:parallel. For looking after memory problems the Intel Parallel Inspector may help. I doesn't look like you want to detect data races here (the Parallel Inspector would also be a good choice to detect them).
Of course we will takeyour reported issue seriously and try to reproduce this, but in your case I think you can safelyremove option /debug:parallel for now.
Regards, Hubert.
I've already run Parallel Inspector. Obviously, I wouldn't ship a product with /debug:parallel enabled and release builds don't produce the link error anyway.
I do have much data sharing going on and OpenMP is perhaps not the best solution, but it's the hand I've been dealt. It's tedious, but /debug:parallel does allow me to check whether the events it shows are real problems - ie. is the data protected by a mutex etc..
Orin.
