My ICC version intel_parallel_studio_xe_2015_update1, trial version.
I used following command to compile,
icc -w -fpermissive -fPIE -I. -DMKL_ILP64 -DLINUX -std=c++11 -g0 -O3 -c xx.cpp -o /tmp/xx.o
xiar rcs /tmp/xx.a /tmp/xx.o
and use following command to link.
icc /tmp/release/*.o -o release/yy -L/opt/intel/composer_xe_2015.3.187/lib/intel64 -L/opt/intel/composer_xe_2015.3.187/mkl/lib/intel64 -Wl,--start-group /opt/intel/composer_xe_2015.3.187/mkl/lib/intel64/libmkl_core.a /opt/intel/composer_xe_2015.3.187/mkl/lib/intel64/libmkl_intel_lp64.a /opt/intel/composer_xe_2015.3.187/mkl/lib/intel64/libmkl_sequential.a /opt/intel/composer_xe_2015.3.187/compiler/lib/intel64/libiomp5.a /opt/intel/composer_xe_2015.3.187/compiler/lib/intel64/libirc.a -Wl,--end-group -L. -Bdynamic -lm -Bstatic -pthread -lstdc++ -ldb -lsqlite3
when I get binary yy as above, used objdump -t yy|grep debug, it will show.
0000000000000000 l d .debug_aranges 0000000000000000 .debug_aranges
0000000000000000 l d .debug_info 0000000000000000 .debug_info
0000000000000000 l d .debug_abbrev 0000000000000000 .debug_abbrev
0000000000000000 l d .debug_line 0000000000000000 .debug_line
0000000000000000 l d .debug_str 0000000000000000 .debug_str
0000000000000000 l d .debug_loc 0000000000000000 .debug_loc
0000000000000000 l d .debug_ranges 0000000000000000 .debug_ranges
That I think it is a debug version, but actually, I do compile release version.
My gcc is 4.9.2 compile from source code and instead of system default gcc (4.4) , os is centos6.6.
2.6.32-504.el6.x86_64 #1 SMP Wed Oct 15 04:27:16 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/lto-wrapper
Target: x86_64-redhat-linux
Configured with: ../gcc-4.9.2/configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-languages=c,c++ --disable-dssi --with-ppl --with-cloog --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux --disable-multilib
Thread model: posix
gcc version 4.9.2 (GCC)
When I used gcc to compile, it should no issue. binary for gcc is about 5.2M, and for icc is 11M.
Please advise any solution?
yixuan
Do you not expect -g0 option to require debug symbols?
-g0 is my second try when it shows debug information even without that parameter.
my first try is using following parameter:
icc -w -fpermissive -fPIE -I. -DMKL_ILP64 -DLINUX -std=c++11 -O3 -c xx.cpp -o xx.o
