Intel® C++ Compiler
7956 Discussions
different result in gcc & icc in throwing exceptions
Milind_Kulkarni__Int
New Contributor II
I have following code which gives different output for g++ and icc across all versions of the compilers in Linux*.
[bash]#include
using namespace std;
int getInt(int i) throw(int) {
	throw i;
	return i;
int main() {
	try {
		try {
			cout << getInt(10) << " " << getInt(20) << endl;
		catch(int f) {
			cout << "int: " << f << endl;
			throw;
	catch(int i) {
		cout << "outer int: " << i << endl;
	return 0;
[/bash]
With g++ any version:-- output is
./a.out
int: 20
outer int: 20
With icc any version, output is:--
./a.out
int: 10
outer int: 10
Is that the icc seems to work right.
What is the reason for this difference in results.
New Contributor II
When I use:--
int getInt(int i) throw()
instead of
I get this following error for both g++ and icc/icpc
./a.out
terminate called after throwing an instance of 'int'
Aborted
But the throw() syntax should also work. Please correct me if wrong.
Judith_W_Intel
To answer the last question the throw() specification syntax means this function should not throw anything. So terminate is called when any throw occurs, no matter what the type.
New Contributor II
Hi Judy,
The same throw() syntax works correctly in Windows* systems for icl and Microsoft* compilers , and also the runtime output also seems to be the same for both.
Then why does throw() syntax not work in Linux*.
Judith_W_Intel
It is actually working correctly on Linux andincorrectly on Windows, because the Microsoft compiler allows one to specify throw specifications but omits the standard-mandate runtime behaviorif you violate them.
Judy
New Contributor II
Okay thanks got it. I will have to throw differently in Linux* & Windows* , applying slightly different syntax, and it will work.
My only more question that is unanswered is:--
I get different result in icc vs g++ (across all versions).
In the former, I get 10, in the latter I get 20. What can be the logic for this.
Which is the correct result.
Judith_W_Intel
According to the standard the behaviour is undefined here (and if you promote the remark to warning by using the -ww981 option you'll see our compiler gives a diagnostic):
t.cpp(11): warning #981: operands are evaluated in unspecified order
printf("%d %d\n",getInt(10),getInt(20));
But I think we should try to match the behaviour of Gnu in our Linux compiler.
A possible workaround for now is to use the -rev_arg_eval option which reverse the order of evaluation of the arguments so getInt(20) is evaluated first.
Judy
kfsone
I interviewed for Yahoo! in 2004, and they used this as an interview question :) I thought it was defined, but the behavior is undefined because of the way arguments are passed under different environments/calling conventions :)
For instance - if the values are being passed via the stack, they may be loaded backwards, whereas if they are being passed in registers, they may be loaded in the written order.
