I have following code which gives different output for g++ and icc across all versions of the compilers in Linux*.
[bash]#include/////////////////////////////////using namespace std; int getInt(int i) throw(int) { throw i; return i; } int main() { try { try { cout << getInt(10) << " " << getInt(20) << endl; } catch(int f) { cout << "int: " << f << endl; throw; } } catch(int i) { cout << "outer int: " << i << endl; } return 0; } [/bash]
With g++ any version:-- output is
./a.out
int: 20
outer int: 20
With icc any version, output is:--
./a.out
int: 10
outer int: 10
Is that the icc seems to work right.
What is the reason for this difference in results.
int getInt(int i) throw()
instead of
I get this following error for both g++ and icc/icpc
./a.out
terminate called after throwing an instance of 'int'
Aborted
But the throw() syntax should also work. Please correct me if wrong.
Hi Judy,
The same throw() syntax works correctly in Windows* systems for icl and Microsoft* compilers , and also the runtime output also seems to be the same for both.
Then why does throw() syntax not work in Linux*.
Judy
Okay thanks got it. I will have to throw differently in Linux* & Windows* , applying slightly different syntax, and it will work.
My only more question that is unanswered is:--
I get different result in icc vs g++ (across all versions).
In the former, I get 10, in the latter I get 20. What can be the logic for this.
Which is the correct result.
According to the standard the behaviour is undefined here (and if you promote the remark to warning by using the -ww981 option you'll see our compiler gives a diagnostic):
t.cpp(11): warning #981: operands are evaluated in unspecified order
printf("%d %d\n",getInt(10),getInt(20));
But I think we should try to match the behaviour of Gnu in our Linux compiler.
A possible workaround for now is to use the -rev_arg_eval option which reverse the order of evaluation of the arguments so getInt(20) is evaluated first.
Judy
