what is the fastest way to test at runtime, to machine accuracy,
if double d2 is between d1 and d3 while not knowing d1 and d3 in advance?
double d1 =...;
double d2 =...;
double d3=...;
if ( d1>d3 && d1>=d2 && d2>=d3 ) || ( d1
regards,
The answer is highly platform and data dependent. You might consider whether & in place of &&, | in place of ||, might be appropriate for your case.
win64
core2 (up to ssse3) and penryn (sse4)
d1, d2, d3 are all within 0.0 and 1.0 range, but often between 0.0 and 0.1 range. relevant precision is 4th decimal.
i don't see how to use the bit-and and bit-or instead of logical ones.
rds,
// highest prob. lowest prob.
if((d1// d2 between d1 and d3 regardless of sign
order the expressions left to right in order of highest probability
If your code requires d1 < d3 then use only left expression
Jim
