I get a segfault the moment I invoke ecc...without even giving it any files to compile.
vikram@dvl27 663: ecc Segmentation fault (core dumped)
This is an redhat itanium 2 box
vikram@dvl27 665: cat /etc/redhat-release
Red Hat Linux Advanced Server release 2.1AS (Derry
vikram@dvl27 666: cat /proc/cpuinfo
processor : 0
vendor : GenuineIntel
arch : IA-64
family : Itanium 2
model : 1
revision : 5
archrev : 0
features : branchlong
cpu number : 0
cpu regs : 4
cpu MHz : 1495.974000
itc MHz : 1495.974000
BogoMIPS : 2239.75
Any ideas??
processor : 0
arch : IA-64
family : Itanium 2
model : 1
revision : 5
archrev : 0
cpu number : 0
cpu regs : 4
BogoMIPS : 2239.75
Any ideas??
Have you set up the environment with eccvars.sh script? If so, can you cut and paste the output of "icid" here? Thanks.
Brandon
Intel Developer Support
For on-line assistance: http://support.intel.com/support/performancetools
For user forums: http://intel.com/ids/community
For product support information: http://www.intel.com/software/products/support
* Intel and Pentium are registered trademarks of Intel Corporation or its subsidiaries in the United States and other countries
* Other names and brands may be claimed as the property of others
Brandon
Yes, I did run eccvars(.sh)
I ran icid and here's the output
OS information:
Red Hat Linux Advanced Server release 2.1AS (Derry)
Kernel on an m
Kernel 2.4.18-e.37smp
glibc-2.2.4-32.3
Support Package IDs for Intel Compilers in /lsi/soft/intel/ccompiler/linux/7.1.20031112/compiler70/ia32/bin
Please use the following information when submitting customer support requests.
It looks like icid _also_ core dumped!! The same installation is also visible from a 32-bit Xeon box, so I ran icid from there. It ran ok. Heres the output...
OS information:
Red Hat Linux release 7.2 (Enigma)
Kernel on an m
Kernel 2.4.7-10smp
glibc-2.2.4-13
C++ Support Package ID : l_cc_pc_7.1.031-XXX
IDB Support Package ID : l_cc_pc_7.1.031-XXX
All Installed Compiler Components on this OS:
intel-icc7-7.1-6: Intel C++ Compiler for 32-bit applications, Version
7.1 Build 20030307Z
intel-isubh7-7.1-6: Substitute Headers for Intel C++ Compiler for
32-bit applications, Version 7.1
--Vikram
OS information:
Kernel on an m
glibc-2.2.4-32.3
OS information:
Kernel on an m
Kernel 2.4.7-10smp
glibc-2.2.4-13
7.1 Build 20030307Z
--Vikram
