Intel® C++ Compiler
7953 Discussions
eclipse ide use intel gdb-oneapi debugger error
liu_wei67
hi:
First, I have integrated the relevant oneapi debugger toolkit into eclipse.
Then I created a c++ project and built it, configured its Debugger Configurations
then i choose gdb-oneapi C/C++ Remote Application
then i click Select other...
then i click Dubugger to settings
then i settings Connection
then i use xshell to start a gdbserver
then i click Apply and Debug  from eclipse
but its error
then I followed the prompts and configured the share libraries
But it still says error
so i dont know how to  solve it
Eclipse IDE Version: 2021-03 (4.19.0)
oneapi debugger: 2021.6.0
Server: linux (i use x11 to start a eclipse)
Viet_H_Intel
Seems like libipt.so.2.* is missing.
If you call, gdb-oneapi from the command line, does it work?
$ gdb-oneapi a.out
GNU gdb (Intel(R) Distribution for GDB* 2022.2) 11.2
Copyright (C) 2022 Free Software Foundation, Inc.; (C) 2022 Intel Corp.
Reading symbols from a.out...
(gdb)
According to the Release Notes, only Eclipse 4.20 and 4.21 are supported.
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-dpcpp-system-requirements.html.
Can you update your Eclipse to 4.20 or 4.21 and give it another try?
liu_wei67
Hi:
gdb-oneapi from the command line, it work no  problem.
I changed the version of eclipse, but it still has this problem.
so how to solve this problem
Viet_H_Intel
Can you let us know what OS version you installed oneAPI?
liu_wei67
Hi:
linux:CentOS Linux release 8.3.2011
Viet_H_Intel
CenOS isn't listed as a supported OS. Please see Software Requirements at https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-dpcpp-system-requirements.html
liu_wei67
Hi:
Thank you for your reply, but what I want to know is that I am using Centos 8.3 with the oneapi toolkit installed, will it also affect me to use the DPC++ Compiler in the oneapi toolkit? Since the URL you gave is titled "Intel® oneAPI DPC++/C++ Compiler System Requirements", do I need to change my OS to use these?
Viet_H_Intel
Yes, it is recommended to use the oneAPI on supported OS.
liu_wei67
hi:
Okay, I got it., thank you very much
liu_wei67
hi:
I changed to another system as requested, but I still get the gdboneapi --version not found error on eclipse
OS:Red Hat Enterprise Linux release 8.5 (Ootpa)
Eclipse IDE Version: 2021-09 (4.21.0)
Viet_H_Intel
Let me work with our integration team and get back to you.
liu_wei67
hi:
Thank you very much, I will wait for your reply
thanks
Viet_H_Intel
Did you "source /your_intalled_dir/oneapi/setvars.sh" prior to launching the Eclipse?
liu_wei67
hi:
Thank you very much for the heads up,
I thought I only needed to source /opt/intel/oneapi/setvars.sh on the server where I started gdbserver.
I didn't source setvars.sh before starting eclipse.
Now I source /opt/intel/oneapi/setvars.sh before starting eclipse, and it works fine for debugging.
I am not too familiar with eclipse, so I would like to know if I can set source /opt/intel/oneapi/setvars.sh in eclipse instead of going to source /opt/intel/oneapi/setvars.sh on the command line in the background.
thanks
Viet_H_Intel
I think you should source setvars.sh in Eclipse.
Since it worked, can we close this thread?
liu_wei67
hi:
Yes, you can close this thread.
Viet_H_Intel
This thread is now closed.
