Intel® C++ Compiler
enum namespace conflict
jimdempseyatthecove
C++ from Parallel Studio XE 2017 Cluster Edition, Windows 7
enum StiffnessModel
    Seed = 1,
    Chord = 2
Produces namespace collision with
C:\Program Files (x86)\Windows Kits\8.1\Include\um\wingdi.h(3615): error : "Chord" has already been declared in the current scope
1>     WINGDIAPI BOOL  WINAPI Chord( _In_ HDC hdc, _In_ int x1, _In_ int y1, _In_ int x2, _In_ int y2, _In_ int x3, _In_ int y3, _In_ int x4, _In_ int y4);
My work around is to change the name in the enum (Chord_sm).
Jim Dempsey
jimdempseyatthecove
Note, using C++ from Parallel Studio XE 2017 Cluster Edition, Linux produces no err (due to no wingdi.h).
Minor annoyance.
Jim Dempsey
Judith_W_Intel
The Intel compiler just uses the Windows headers on the system so I don't think we can do anything about namespace pollution from the Microsoft supplied headers. Microsoft gives a similar error so this is not a compiler bug.
!% cat foo.cpp
#include <windows.h>
enum StiffnessModel
    Seed = 1,
    Chord = 2
!% cl -c foo.cpp
Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24210 for x64
Copyright (C) Microsoft Corporation.  All rights reserved.
foo.cpp
foo.cpp(8): error C2365: 'Chord': redefinition; previous definition was 'functio
n'
//hrcna01a.nh.intel.com/wref1/ref/vs2015u3/Windows Kits/10/include/10.0.10586.0/
um\wingdi.h(3676): note: see declaration of 'Chord'
jimdempseyatthecove
The following comment (opinion) may be more of a C++ language thing...
Due to the fact that the C++ compiler can understand:
    StifnessModel::Chord
IOW in the scope of the enum StiffnessModel...
And that the compiler can disambiguate between different signature functions, say Chord with different arguments...
... given the fact (additional information) that the statement in question scoped the enum:
if (layer.materialType == MaterialType::unbound && layer.unbound.stiffModel == StiffnessModel::Chord)
The explicit scoping should have removed any ambiguity as to what to reference.
Jim Dempsey
Judith_W_Intel
If you want the enumerator names to be hidden then you can use the c++11 scoped enum feature, i.e. this compiles fine (notice the class keyword after enum):
enum class StiffnessModel
    Seed = 1,
    Chord = 2
http://stackoverflow.com/questions/18335861/why-is-enum-class-preferred-over-plain-enum
Judy
jimdempseyatthecove
Thanks Judy.
Jim Dempsey
