Intel® C++ Compiler
error 010101_0
Marián__VooDooMan__M
New Contributor II
Greetings,
I was trying (latest) ICC 15.0.1 (Update 1) and got this error in LTCG IPO phase:
c:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\include\thread(55) (col. 3): : error : 010101_0
any ideas?
Shenghong_G_Intel
Hi Marian,
Intel compiler provides the pragma for you to disable optimization for a specific function only. See below for example:
__declspec(noreturn) void MOZ_NoReturn() {}
// With this pragma, it works.
#pragma intel optimization_level 0
void AddRef(int a) {
	if (a>10) {	// add a condition here, or it will not be reproduced...Note: the internal error points to this line.
		::MOZ_NoReturn();
You may try adding that for <thread> header to see whether it works. What is special for your case is, it happens in a system header file, but the option to disable optimization should still work, let me know if it does not work for you. :)
Shenghong
MalReddy_Y_Intel
Thanks for reporting your issue, its sort of Internal compiler error with IPO.
We would need a complete test code to reproduce the issue and help you further.
Reddy
Shenghong_G_Intel
@Marian,
I have a very similar issues found working on another issue (https://software.intel.com/en-us/forums/topic/535459), although the internal error message is different, I found another error during cut down the test case for that issue, which is same with what you reported.
Also, I have check the thread header file as you provided, it looks like to be totally same error as I found. The test case to reproduce the internal error as below (really simple):
// foo.cpp
// icl foo.cpp /Qip -c
// foo.cpp(8) (col. 2): internal error: 010101_0
// works with "icl foo.cpp /Qipo -c", but may still fail during final linking stage.
		::MOZ_NoReturn();
Now, check thread header of same VS version, I see below contents at line thread(55) (col. 3):
	~thread() _NOEXCEPT
		{	// clean up
		if (joinable())  // Note: this is line #55
			_XSTD terminate();
And terminate() is defined as "noreturn", which looks like to same root cause with the existing issue I found yesterday.
You may double confirm and see whether it is same known issue. :) The workaround is to disable optimization for this function.
Shenghong
Shenghong_G_Intel
@Marian,
One good news is, the issue is already fixed (developer is so fast!!!) in mainline. :)
If your issue's root cause is same with my test case, you should see the working version in next update.
Shenghong
New Contributor II
It's good to hear this. but how do I disable optimization for this particular STL (inline) function that is included in all units, as a pre-compiled header?
TIA!
New Contributor II
IMO it would be really cool if Intel would make nightly builds at least two times a week for use on one's own risk. I was waiting few months for ICC 15.0.1 when compile bugs were fixed. Now I got stuck again.
Shenghong_G_Intel
Hi Marian,
		::MOZ_NoReturn();
Shenghong
New Contributor II
Greetings,
yes, workaround
// VDM_BEGIN
#if defined(__INTEL_COMPILER_BUILD_DATE) && __INTEL_COMPILER_BUILD_DATE == 20141023 // workaround for bug in ICC 15.0.1 (Update 1)
#   pragma intel optimization_level 0
#endif
// VDM_END
	~thread() _NOEXCEPT
worked for me.
Thank you.
Shenghong_G_Intel
Hi Marian,
FYI. This issue should have been fixed (same with thread https://software.intel.com/en-us/forums/topic/535459). Please verify with v15.0 update 2 release (w_ccompxe_2015.2.179.exe).
Shenghong
