Hi All,
I am using Intel Composer XE 2013 with Visual Studio 2010 SP1 and when I reach step: "Build Using PGO and run" I gat a strange error message. I think it is in connection with Intel C++ Compiler.
I created a very simple console project(attached the source) and the error message in the release_pg directory is below. What can be the problem here?
Zsolt
Build started 2013.01.03. 14:43:18. 1>Project "c:\Users\Zsolt\documents\visual studio 2010\Projects\tesztcppconsole\tesztcppconsole\tesztcppconsole.vcxproj" on node 2 (build target(s)). 1>InitializeBuildStatus: Creating "Release_PG\tesztcppconsole.unsuccessfulbuild" because "AlwaysCreate" was specified. MessageBuildingWithCompiler: Building with Intel(R) C++ Compiler XE 13.0 ClCompile: ***** ClCompile (Win32 - Intel C++) All outputs are up-to-date. C:\Program Files\Intel\Composer XE 2013\bin\ia32\icl.exe /c /Qvc10 /Qlocation,link,"$(VCInstallDir)\bin" /Zi /nologo /W3 /O2 /Oi /Qipo /Qftz- /D WIN32 /D NDEBUG /D _CONSOLE /D _UNICODE /D UNICODE /EHsc /MD /GS /Gy /fp:fast /QxHost /Zc:wchar_t /Zc:forScope /Qprof-use /Qprof-dir "c:\Users\Zsolt\documents\visual studio 2010\Projects\tesztcppconsole\tesztcppconsole\Release_PG\\" /Fo"Release_PG\\" /Fd"Release_PG\vc100.pdb" /Gd /TP tesztcppconsole.cpp tesztcppconsole.cpp error #30008: Unable to create lock file, c:\Users\Zsolt\documents\visual studio 2010\Projects\tesztcppconsole\tesztcppconsole\Release_PG" -diag_enable_disable_vector E:level3\pgopti.dpi.lock. 1>C:\Program Files\MSBuild\Microsoft.Cpp\v4.0\Platforms\Win32\PlatformToolsets\Intel C++ Compiler XE 13.0\Microsoft.Cpp.Win32.Intel C++ Compiler XE 13.0.targets(272,5): error MSB6006: "icl.exe" exited with code 1. 1>Done Building Project "c:\Users\Zsolt\documents\visual studio 2010\Projects\tesztcppconsole\tesztcppconsole\tesztcppconsole.vcxproj" (build target(s)) -- FAILED.
Build FAILED.
Time Elapsed 00:00:00.11
Sergey Kostrov wrote:In which directory do you mean? I created a file pgopti.dpi.lock in C:\Users\Zsolt\Documents\Visual Studio 2010\Projects\tesztcppconsole\tesztcppconsole\Release_PG. But the message is the same. I also checked the access rights and everybody has full control to this release_pg library.>>...error #30008: Unable to create lock file...
It looks like an Access Rights related problem for release_pg directory but I could be wrong. I would simply try to manually create a file in the folder.
Yes
VADIM G. (Intel) wrote:
Hi Zsolt,
Thanks for reporting the issue! This is a bug in icl. Currently it's assigned to the appropriate engineer and will be fixed in one of the updates.
As a workaround, try to avoid spaces in paths. You may use non default Profile Directory path. Open PGO dialog and change Profile Directory from $(IntDir) to "c:\temp\profile".Regards,
Vadim G.
Thanks Vadim for the work around.
Anoop
Hi Zsolt
We believe the issue fixed now. I will let you know when this is pushed to production for customers. Again thanks for reporting this issue.
Anoop
Hi Zsolt,
This issue is fixed. Please use the latest version of the Intel C++ Compiler.
Thanks and Regards
Anoop
It looks more like compiler generated error.
Greetings,
a quick Google search gave me that there is issue "DPD200239855" in Intel internal tracker about this.
It looks like it was resolved in 2013, March, by Update 3: https://software.intel.com/en-us/articles/intel-composer-xe-2013-compilers-fixes-list
Best
Or was not (fully)?
