Intel® C++ Compiler
7876 Discussions
error #31001: The dll for reading and writing the pdb (for example, mspdb110.dll) could not be found on your path
Guillaume_A_2
Hi everyone,
I recently upgraded my Intel Composer version (2016 -> 2017 update 1) and cannot compile my program anymore in 32bit mode. I get this error :
"error #31001: The dll for reading and writing the pdb (for example, mspdb110.dll) could  not be found on your path"
I found this similar topic but in my case it works fine in 64bit and crash in 32bit. The compilation crash in command line and in Visual Studio.
My config: Win7 (64bit), Visual Studio 2013, Platform Toolset: Intel C++ Compiler 17.0, Base Platform Toolset: V100.
Can someone help me please ?
Guix
Yuan_C_Intel
Hi, Guix
I think your Base Platform Toolset should be v120 for Visual Studio 2013. (v100 is for older Visual Studio 2010)
Please also make sure the mspdb120.dll can be found from "C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\BIN\" installation path.
Hope this helps.
Thank you.
Guillaume_A_2
Thx for your reply Yolanda.
Actually, it works fine when setting the Base Platform Toolset to v110 or v120. But I am stuck with v100 because of dependencies on old thirdparties and I cannot switch my program to a newer toolset.
I tried to add "C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE;C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\amd64" in the PATH (locations of mspdb100.dll). Now the compilation 32bit is OK but it crash at link time with :
"error MSB6006: "xilink.exe" exited with code -1073741701"
It still works fine in 64bit with v100 (or v110 or v120) Base Platform Toolset. What is wrong with the 32bit mode ?
Any other advice ?
Guix
Yuan_C_Intel
Hi, Guix
The path "C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\amd64" is for 64bits binary and dlls instead of 32bits.
Could you find the x86 mspdb100.dll from "C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin"?
Guillaume_A_2
Hi Yolanda,
I reinstalled (two times) VS 10 and then Composer 2017 Update 1. At "C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin" there is two folders: "amd64" and "x86_amd64". I find mspdb100.dll in "amd64"  but not in  "x86_amd64". I also find mspdb100.dll at "C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE", I do not know if it is a 32bit or 64bit dll.
Please note that everything works fine if I switch back to Composer 2016.
I noticed that during the installation of Composer 2017 Update 1 there is no checkbox for Visual Studio 2010 at the "Choose Integration Target" step. Is Composer still compatible with VS 2010 ?
Guix
TimP
Black Belt
The release notes should confirm if vs2010 support was dropped. Historically, Intel compilers have supported at most 3 vs versions.
Guillaume_A_2
Oh no... you are right Tim. Page 7 of the release note : "Support removed for Visual Studio 2010"
Does the mspdb*.dll really needed for the compilation ? Is there a workaround ?
It is ok with 64bit, I am pretty sure that there is a little trick for the 32bit mode.
Guix
TimP
Black Belt
pdb comes into play only when you build with a debug option (e.g. -debug:inline-debug-info, or full debug build).  Even then, if there is a problem, it will only prevent debug symbols from appearing to implement debugging and profiling; it won't affect execution otherwise.
