Intel® C++ Compiler
7956 Discussions
error #791: calling convention specified more than once
phastphill
I recently upgraded the Intel C++ Compiler in my build environment from v11 (067) to v12 (12.0.1.127 Build 20101116).
With the new compiler, I get error #791 when compiling rpcndr.h (a header in the MS Windows DDK). The same file compiles without issue with v11.
The offending lines of code are lines 1428-1446:
RPCRTAPI
unsigned char * RPC_ENTRY
RPC_ENTRY
NdrCsArrayUnmarshall(
PMIDL_STUB_MESSAGE pStubMsg,
unsigned char ** ppMemory,
PFORMAT_STRING pFormat,
unsigned char fMustAlloc
RPCRTAPI
RPC_ENTRY
NdrCsTagUnmarshall(
Documentation of the error is sparse:
Why does this cause errors in v12 and not with v11?
Phill Williams
Judith_W_Intel
This diagnostic is never an error by default. It is only a warning. You must be doing something special (like using the /WX command line option) to turn this warning into an error.
The warning occurswhen you specify the same calling convention more than once on a functiondeclaration, i.e.:
void __cdecl __cdecl foo();
If you preprocess the file (using -E or -P) you should be able to see the actual declarations after macro expansion.
Judy
Judith_W_Intel
Judy
phastphill
Thank you -- it appears that the WDK build infrastructure inserts /WX by default. Overriding this fixed my build.
