Intel® C++ Compiler
error LNK2019
Pannagendra_k_
hi Team,
i am working ICC compiler 2015 (Composer XE 2015).
i am facing a strange error mentioned below,
main.obj : error LNK2019: unresolved external symbol __intel_new_feature_proc_init referenced in function main.
This will occur when i build in Release x64 mode. However Debug x64 mode is working fine.
Also i am able to build same project in both modes with ICC compiler 2013 without any problem.
Please suggest me i am new to this.
SergeyKostrov
Valued Contributor II
>>... >>main.obj : error LNK2019: unresolved external symbol __intel_new_feature_proc_init referenced >>in function main. >> >>This will occur when i build in Release x64 mode. However Debug x64 mode is working fine. Take a look at Linker options for both configurations and for VS 2013 and 2015 project files ( extensions .vcproj ) to verify that they Not differ. Also, I wonder if any IPO options are used?
Judith_W_Intel
If you search the forum you'll see this has been asked a couple of times before:
https://software.intel.com/en-us/forums/intel-c-compiler/topic/564110
https://software.intel.com/en-us/forums/intel-c-compiler/topic/541943
Do any of these posts help?
Pannagendra_k_
Hi Judith,
i tried the best flagged result from Jennifer J. (Intel). unfortunately result is same.
>>Please set the project property Linker > General > Show Progress to "Show some progress messages", relink, and then post the output
i am using VS 2010, in Linker > General > Show Progress i dont have option "Show some progress messages". so i used, "Display all progress messages (/VERBOSE)". i got the below output.
i did not observed any libirc.lib in output window. please suggest.
Pannagendra_k_
hi,
i would like to update my previous comment, same project is working fine in other machines for ICC compiler 2015.
i compared system variables and environmnet varibles no difference. please suggest.
Pannagendra_k_
Hi All, thank you for your response.
i have resolved the issue now. it was path issue of intel compiler. thank you for your kind support.
