Intel® C++ Compiler
error : assertion failed at: "shared/cfe/edgcpfe/il.c", line 16005
Yang__Richard
Trying to build nodejs  using Intel C++ Compiler. Not going so well. First I had an issue very similar to https://software.intel.com/en-us/forums/intel-c-compiler/topic/733662 related to ICU and UTF8. I fixed it with    -Qoption,cpp,--unicode_source_kind,"UTF-8"  (is a utf-8 flag coming soon?)
Now I've hit errors building the v8 directory. Note first that Visual C++ compiler works fine in building nodejs. My issues are best illustrated by actually running vcbuild.bat from the nodejs github repository (to get a Visual Studio solution file), and then opening up the sln generated, converting it to Intel C++, and building it.
Some errors I've been getting
7>    Error: function "v8::Isolate::operator delete(void *, size_t={unsigned __int64})" (declared at line 8340 of "..\include/v8.h") cannot be referenced -- it is a deleted function
7>
7>    Error: function "v8::Isolate::operator delete[](void *, size_t={unsigned __int64})" (declared at line 8341 of "..\include/v8.h") cannot be referenced -- it is a deleted function
7>
7>    Error: function "Isolate::~Isolate(unsigned int)" (declared implicitly) cannot be referenced -- it is a deleted function
7>    C:\VS2017\Common7\IDE\VC\VCTargets\Platforms\x64\PlatformToolsets\Intel C++ Compiler 19.0\Toolset.targets(383,5): error MSB6006: "icl.exe" exited with code 2.
7>  Done executing task "ICL" -- FAILED.
7>Done building target "ClCompile" in project "v8_libsampler.vcxproj" -- FAILED.
7>Done building project "v8_libsampler.vcxproj" -- FAILED.
7>Build FAILED.
7>
7>C:\VS2017\Common7\IDE\VC\VCTargets\Platforms\x64\PlatformToolsets\Intel C++ Compiler 19.0\Toolset.targets(383,5): error MSB6006: "icl.exe" exited with code 2.
7>    0 Warning(s)
7>    1 Error(s)
7>
7>Time Elapsed 00:00:03.56
Another set of problems
16>    Error: function "v8::Isolate::operator delete(void *, size_t={unsigned __int64})" (declared at line 8340 of "..\include/v8.h") cannot be referenced -- it is a deleted function
16>
16>    Error: function "v8::Isolate::operator delete[](void *, size_t={unsigned __int64})" (declared at line 8341 of "..\include/v8.h") cannot be referenced -- it is a deleted function
16>
16>    Error: function "Isolate::~Isolate(unsigned int)" (declared implicitly) cannot be referenced -- it is a deleted function
16>
16>    C:\VS2017\Common7\IDE\VC\VCTargets\Platforms\x64\PlatformToolsets\Intel C++ Compiler 19.0\Toolset.targets(236,5): error MSB6006: "icl.exe" exited with code 2.
16>  Done executing task "ICL" -- FAILED.
16>Done building target "ClCompile" in project "v8_base.vcxproj" -- FAILED.
16>
16>Done building project "v8_base.vcxproj" -- FAILED.
16>
19>    Error: function "v8::Isolate::operator delete(void *, size_t={unsigned __int64})" (declared at line 8340 of "..\include/v8.h") cannot be referenced -- it is a deleted function
19>
19>    Error: function "v8::Isolate::operator delete[](void *, size_t={unsigned __int64})" (declared at line 8341 of "..\include/v8.h") cannot be referenced -- it is a deleted function
19>
19>    Error: function "Isolate::~Isolate(unsigned int)" (declared implicitly) cannot be referenced -- it is a deleted function
19>
17>    Error: function "v8::Isolate::operator delete(void *, size_t={unsigned __int64})" (declared at line 8340 of "..\include/v8.h") cannot be referenced -- it is a deleted function
17>
17>    Error: function "v8::Isolate::operator delete[](void *, size_t={unsigned __int64})" (declared at line 8341 of "..\include/v8.h") cannot be referenced -- it is a deleted function
17>
17>    Error: function "Isolate::~Isolate(unsigned int)" (declared implicitly) cannot be referenced -- it is a deleted function
17>
18>    Error: function "v8::Isolate::operator delete(void *, size_t={unsigned __int64})" (declared at line 8340 of "..\include/v8.h") cannot be referenced -- it is a deleted function
18>
18>    Error: function "v8::Isolate::operator delete[](void *, size_t={unsigned __int64})" (declared at line 8341 of "..\include/v8.h") cannot be referenced -- it is a deleted function
18>
18>    Error: function "Isolate::~Isolate(unsigned int)" (declared implicitly) cannot be referenced -- it is a deleted function
19>
19>
19>
19>
19>
19>
19>
19>    C:\VS2017\Common7\IDE\VC\VCTargets\Platforms\x64\PlatformToolsets\Intel C++ Compiler 19.0\Toolset.targets(383,5): error MSB6006: "icl.exe" exited with code 2.
19>  Done executing task "ICL" -- FAILED.
19>Done building target "ClCompile" in project "v8_nosnapshot.vcxproj" -- FAILED.
19>
19>Done building project "v8_nosnapshot.vcxproj" -- FAILED.
17>    compilation aborted for ..\src\setup-isolate-full.cc (code 2)
17>    del Z:\USER\TMP\409961tempfile3
17>    del Z:\USER\TMP\409962arg4
17>    del Z:\USER\TMP\dshFE51.tmp
17>    C:\VS2017\Common7\IDE\VC\VCTargets\Platforms\x64\PlatformToolsets\Intel C++ Compiler 19.0\Toolset.targets(383,5): error MSB6006: "icl.exe" exited with code 2.
17>  Done executing task "ICL" -- FAILED.
17>Done building target "ClCompile" in project "v8_init.vcxproj" -- FAILED.
17>
17>Done building project "v8_init.vcxproj" -- FAILED.
17>
18>    builtins-collections-gen.cc
18>
18>
18>    C:\Github\node\deps\v8\src\x64\assembler-x64.h(120): error : assertion failed at: "shared/cfe/edgcpfe/il.c", line 16005
18>
18>          Register::ListOf<rax, rcx, rdx,
18>          ^
18>
18>    builtins-array-gen.cc
18>
18>
Note that towards the end of the above snippet is where the topic title "error: assertion failed..." comes from.
Then there are a bunch of repeat errors for 18> above, but there is also this:
18>    C:\Github\node\deps\v8\src\x64\assembler-x64.h(120): error : access violation
18>          ^
And concluding it all...
21>Target ComputeCustomBuildOutput:
21>  Task "CreateItem" skipped, due to false condition; ('%(CustomBuildOutputs.OutputItemType)'!='') was evaluated as (''!='').
21>  Task "MakeDir"
21>  Done executing task "MakeDir".
21>Target CustomBuild:
21>  Using "GetOutOfDateItems" task from assembly "C:\VS2017\Common7\IDE\VC\VCTargets\Microsoft.Build.CppTasks.Common.dll".
21>  Task "GetOutOfDateItems"
21>  Done executing task "GetOutOfDateItems".
21>  Task "ParallelCustomBuild" skipped, due to false condition; ('@(_ParallelCustomBuild)' != '') was evaluated as ('' != '').
21>  Using "CustomBuild" task from assembly "C:\VS2017\Common7\IDE\VC\VCTargets\Microsoft.Build.CppTasks.Common.dll".
21>  Task "CustomBuild"
21>    Write Tracking Logs:
21>    	Release\obj\v8_snapshot\v8_snapshot.tlog\custombuild.write.1.tlog
21>    Read Tracking Logs:
21>    	Release\obj\v8_snapshot\v8_snapshot.tlog\custombuild.read.1.tlog
21>    No output for C:\GITHUB\NODE\RELEASE\MKSNAPSHOT.EXE was found in the tracking log; source compilation required.
21>    C:\Github\node\Release\\mksnapshot.exe will be compiled because it was not found in the tracking log.
21>    call call C:\Github\node\Release\mksnapshot.exe "--turbo_instruction_scheduling" "--startup_src" "Release\obj\v8_snapshot\snapshot.cc"
21>    if %errorlevel% neq 0 exit /b %errorlevel%
21>    generating: "Release\obj\v8_snapshot\/snapshot.cc"
21>    'C:\Github\node\Release\mksnapshot.exe' is not recognized as an internal or external command,
21>    operable program or batch file.
21>    C:\VS2017\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(209,5): error MSB6006: "cmd.exe" exited with code 1.
21>  Done executing task "CustomBuild" -- FAILED.
21>Done building target "CustomBuild" in project "v8_snapshot.vcxproj" -- FAILED.
21>
21>Done building project "v8_snapshot.vcxproj" -- FAILED.
21>
Viet_H_Intel
Can you verify if the assertion comes from compiling builtins-array-gen.cc, then create a preprocess file for us to investigate?
Also what Intel Compiler version and Visual Studio version?
Viet
Yang__Richard
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.0.117 Build 20180804 (as part of the Intel Parallel Studio XE suite.)
Using Visual Studio 2017 Enterprise 15.8.7
I'll verify the builtins-array-gen.cc, and get back to you.
Yang__Richard
Here is the preprocess file,
Viet_H_Intel
Hi Richard,
Visual Studio 2017 version 15.8.7 was released on Oct-10 and ICL 19.0 released on Aug-4
Can you try to see if you still get this error on the older version of Visual Studio?
Viet
Yang__Richard
Unfortunately I cannot readily access a different version of Visual Studio. I highly doubt the issue is related to how new Visual Studio
Viet_H_Intel
Ok, I tried to compile your i. file but was not able to.
Can you please ensure that .i can be compiled successfully? And also provide us your command line options.
Viet
Viet_H_Intel
What I meant is to see the shared/cfe/edgcpfe/il.c", line 16005 when compiles i. file.
I saw other error messages but not the above one.
Yang__Richard
When I produced the i file I simply added the /P switch to icl.cfg and right clicked the file from Solution Explorer and clicked Compile from the context menu. It was produced successfully. If I tried to compile the file without the /P switch it would fail. I'm not at my computer atm So I'll get back to you for those files you mentioned in a few hours probably
Yang__Richard
Alright since I'm unsure of what is wanted/needed, so I'll first post a ZIP archive of *all* the diagnostic MSBuild build logs from "Build Solution", including the ones I didn't mention to have errors.
I believe the build options are in there somewhere.
Note that builtins-array-gen.cc  is in the project v8_initializers, so the log file in the zip archive is named v8_initializers.log
And from what I can tell, the `icl builtins-array-gen.i` does not compile (ie.  I get a code 4 compilation abortion).
Viet_H_Intel
I looked at your log files, got the command lines options but still could be able to compile builtins-array-gen.i to get the error message above.
Yang__Richard
could or could not get the error message?
The only error message I'm getting for compiling builtins-array-gen.cc is "C:\VS2017\Common7\IDE\VC\VCTargets\Platforms\x64\PlatformToolsets\Intel C++ Compiler 19.0\Toolset.targets(383,5): error MSB6006: "icl.exe" exited with code 2."
Viet_H_Intel
I couldn't get "assertion failed at: "shared/cfe/edgcpfe/il.c" on VS2017 (15.7.4)
Yang__Richard
Huh. Well I guess it's not from that file, perhaps?
jim_y_
yes , me too , The same problem
node.js build intel c++
https://github.com/nodejs/node
19.0.0.117
