Intel® C++ Compiler
error: class "__m128" has no suitable assignment operator
Matt_S_2
This code
#include <xmmintrin.h>
volatile __m128 a, b;
void test(void)
     a = b;
produces this error
$ /opt/intel/composerxe/bin/icpc -c test.cc
test.cc(7): error: class "__m128" has no suitable assignment operator
       a = b;
compilation aborted for test.cc (code 2)
when compiled with icpc.  There is no error if the variables are not volatile.  There is no error with icc or gcc or g++.
Any suggestion on how to compile it with icpc?
Shenghong_G_Intel
I've reproduced the issue and the issue is caused by wrong processing in C++ mode. ICC is the C compiler and ICPC is the C++ compiler, if you name your file as ".cpp", even icc will fail (as icc will use icpc for .cpp files).
Is there any reason you must use icpc to compile? You may force icpc to build in C mode to avoid the bug...see below:
$ cat temp.c
#ifndef OK
volatile
#endif
__m128 a, b;
void test(void) { a = b; }
$ gcc temp.c -c
$ g++ temp.c -c
$ g++ -x c++ temp.c -c
$ icc temp.c -c
$ icc -x c++ temp.c -c
temp.c(6): error: class "__m128" has no suitable assignment operator
compilation aborted for temp.c (code 2)
$ icpc temp.c -c
$ icpc -x c temp.c -c
$ icpc temp.c -c -DOK
GNU compiler will build ok in both C and C++ mode, but our compiler will fail in C++ mode. So, the workaround is to use C mode (use .c as file extension with icc, or use -x c for icpc).
Shenghong
Shenghong_G_Intel
FYI. I'll track the issue as DPD200367042 in our problem tracking system.
Shenghong
Matt_S_2
Thanks for the update.  Unfortunately, this is a simplified example from a large code base; compiling it in C mode is not an option.
Shenghong_G_Intel
Hi Matt,
FYI. This issue is fixed in v16.0 beta Update 1 version.
$ source /opt/intel/compilers_and_libraries_2016.0.056/linux/bin/compilervars.sh intel64
$ cat temp.c
#ifndef OK
volatile
#endif
__m128 a, b;
Shenghong
