Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
error code -1073741819
Marián__VooDooMan__M
New Contributor II
2>xilink: : error #10014: problem during multi-file optimization compilation (code -1073741819) 2>xilink: : error #10014: problem during multi-file optimization compilation (code -1073741819) I am using the latest stable 15 version of ICC, and MSVC 2013. What the hell this means? Shouldn't be numbers in error code dated back to 1980's ?! best
New Contributor II
I think I got the root cause of this error.
Either, or both the statically linked library (*.lib) and/or its corresponding *.pdb file has been corrupted, so IPO linker choked on it, so I have rebuilt that static library and the problem disappeared.
But I might be wrong, since I have made many changes since then...
