The following compiles fine under gcc 3.4 and 4.2, but fails under Intel compiler 11.0. Any insights? Thanks.
tls_test.h:
template
class tls_test
static __thread int i;
template
__thread int tls_test::i = -1;
tls_test.cpp:
#include "tls_test.h"
tls_test<2> t;
Compiler output:
$/apps/intel/Compiler/11.0/069/bin/intel64/icpc -c tls_test.cpp
tls_test.h(10): error: template argument list must match the parameter list
Also tried Intel compiler 11.1 (icpc (ICC) 11.1 20090630), same result.
tls_test.h:
template
class tls_test
template
tls_test.cpp:
tls_test<2> t;
Compiler output:
11.0 latest does not fix the problem.
11.1 latest fix the problem.
You should not test with such old compiler version like 20090630 ..
please try latest 11.1 version
