Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7768 Discussions
error: namespace "boost::type_traits" has no member "yes_type"
Hou_y_1
hi, I compile code calling some api of the boost by inter c++ compiler; but met massive errors as follow:
In file included from /usr/local/include/boost/type_traits/is_convertible.hpp(17),
                 from /usr/local/include/boost/math/tools/promotion.hpp(29),
                 from /usr/local/include/boost/math/special_functions/detail/round_fwd.hpp(12),
                 from /usr/local/include/boost/math/special_functions/math_fwd.hpp(27),
                 from /usr/local/include/boost/math/special_functions/fpclassify.hpp(19),
                 from ./include/caffe/common.hpp(5),
                 from ./include/caffe/blob.hpp(8),
                 from ./include/caffe/layers/average_layer.hpp(6),
                 from src/caffe/layers/average_layer.cpp(5):
/usr/local/include/boost/type_traits/is_complete.hpp(61): error: namespace "std" has no member "declval"
           template <class U, class = decltype(sizeof(std::declval< U >())) >
/usr/local/include/boost/type_traits/is_complete.hpp(61): error: type name is not allowed
/usr/local/include/boost/type_traits/is_complete.hpp(61): error: expected an expression
/usr/local/include/boost/type_traits/is_complete.hpp(62): error: namespace "boost::type_traits" has no member "yes_type"
           static type_traits::yes_type check(U*);
/usr/local/include/boost/type_traits/is_complete.hpp(65): error: namespace "boost::type_traits" has no member "no_type"
           static type_traits::no_type check(...);
/usr/local/include/boost/type_traits/is_complete.hpp(67): error: namespace "boost::type_traits" has no member "yes_type"
           static const bool value = sizeof(check<T>(0)) == sizeof(type_traits::yes_type)
info of compiling enviroment:
os: redhat 6.5
gcc: 4.4.7
intel-compiler:
icc version 18.0.3 (gcc version 4.4.7 compatibility)
how can i solve this problem?
Viet_H_Intel
Can you provide us a pre-process file to investigate?
Viet
