Intel® C++ Compiler
7944 Discussions
?? error: no suitable copy constructor
jim_cox
I'm trying to understand the following compiler error
1>OpsData\\PublicRoute.cpp(301): error: class "std::basic_ofstream" has no suitable copy constructor
1> list.Write( oFile ) ;
which would appear to stem from the definition
ofstream oFile ;
where ofstrem is defined in
If I check the function definition in nodelist.cpp
BOOL CPublicRouteNodeList::Write( ofstream oFile )
the ofstream definition also points back to the same definition in
I dont understand why the two defintions - which appear to be identical - wont work
What is trying to do here
I note thaat the code does compile with some other compilers
Any suggestioos?
advTHANKXance yet again
Jimmy
=mjc=
Judith_W_Intel
Instead of trying to copy the parameter by value, copy it by reference, i.e.:
BOOL CPublicRouteNodeList::Write( ofstream& oFile )
Judy
Judith_W_Intel
Judy
jim_cox
Yup - that's it thankx.
