Intel® C++ Compiler
error: parameter pack was referenced but not expanded
Paul_P_5
This is a C++ compiler bug report. (If it should be submitted elsewhere let me know.)
With Intel C++ (2016.0.109) the following error is reported:
$ icpc -std=c++11 icpc-bug.cxx
icpc-bug.cxx(12): error: parameter pack "TS" was referenced but not expanded
  template <typename... TS, TS... vals>
compilation aborted for icpc-bug.cxx (code 2)
zsh: exit 2     icpc -std=c++11 icpc-bug.cxx
with this code (which distilled to a small program that recreates the bug):
template <typename T, T value>
struct bar
template <typename... T>
struct foo
  using type = bool;
struct foo<bar<TS,vals>...>
  using type = bool;
int main()
  foo<bar<int, 1>, bar<long, 3L>> f;
This code is correct C++ and compiles with clang v3.5.0 and GCC (v4.8.x through to and v6 - 20150830).
Amanda_S_Intel
Thanks for the test case. I reproduced this with icpc 16.0 and g++ 4.9.0 and I submitted this issue to the development team (DPD200376943).
Paul_P_5
Any news if this issue has been fixed yet?
