I am using Intel c++ compiler first time. The project uses one library/include directoryc:/ITEX41/libor c:/ITEX41/include.Followed all instructions given in the user guide and tried to compile the project. But it gives error in compiling. Please help me out.
It gives following message:
1>------ Build started: Project: overlay, Configuration: Debug Win32 ------
1>Compiling with Intel C++ 9.1 ...(Intel C++ Environment)
1>stdafx.cpp
1>Command-line error: invalid macro definition: c:ITEX41lib
1>
1>compilation aborted for stdafx.cpp (code 4)
1>overlay.cpp
1>
1>overlayd.cpp
1>compilation aborted for overlay.cpp (code 4)
1>
1>OELEM.CPP
1>compilation aborted for overlayd.cpp (code 4)
1>
1>overlayv.cpp
1>compilation aborted for OELEM.CPP (code 4)
1>
1>mainfrm.cpp
1>compilation aborted for overlayv.cpp (code 4)
1>
1>PROCTHRD.CPP
1>compilation aborted for mainfrm.cpp (code 4)
1>
1>compilation aborted for PROCTHRD.CPP (code 4)
1>
1>Build log was saved at "file://D:ProjectWORKdecoding source codePCVISIONintel c++ compilerVS 2005 multitarget occulusion problem test-5wkg multitarget wo occu at 101600DebugBuildLog.htm"
1>overlay - 0 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Have you perhaps wrote icl -DC:ITEX41lib instead of proper library include switches? It is clearly the problem with command line option as the error reported by the compiler suggests.
