I have problems building boost (1.53) with the beta of Composer 2013 SP1 running on Windows 8 with Visual Studio 2012 Professional installed. Within "Intel 64 Visual Studio 2012 mode" command prompt, in the boost download directory I executed
bootstrap intel-win32
The first part of the script (compilation) succeeds, but then the script fails and in the bootstrap log I can see
C:\boost\boost_1_53_0\tools\build\v2\engine>.\bootstrap\jam0 -f build.jam --toolset=intel-win32 "--toolset-root= " -win32 clean
Invalid option: -w
followed by another failure
Invalid option: -w
So, how to do it?
Slawek
Hi Sergey,
Thanks for your help, but actually I do not see -w option on the command line, I see -win32 and suspect that jam0 takes the first letter of it as -w.
Slawek
Problem of jam0? Or rather a problem of script/whatever calls jam0 with these incorrect parameters?
BTW, by comparing this log to a log of a successful build using MS compiler, I can see that -win32 is not used, it looks like this
bootstrap\jam0 -f build.jam --toolset=vc11 "--toolset-root=C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\Tools\..\..\VC\ " clean
So, I executed
bootstrap\jam0 -f build.jam --toolset=intel-win32 "--toolset-root= " clean
and it worked, but trying to to the same for the second invocation of jam0, and executing
caused jam0 crash.
Slawek
note advice previously given about /w switch for Boost Windows:
/w and -w are equivalent.
See this article on building boost on Windows: http://software.intel.com/en-us/articles/building-boost-with-intel-c/
And this thread on a building issue: http://software.intel.com/en-us/forums/topic/280922
Jennifer
I succeeded eventually with some small hacking, Windows7 and Visual Studio 2010. (so, it appears that either Windows 8 or Visual Studio 2012 is to blame). Steps followed
1. Download boost. In "Intel 64 Visual Studio 2010 mode" command prompt go to the root of the downloaded boost (e.g. D:\boost\boost_1_53_0) and execute
This will fail, as reported above (BTW, I do not believe that this has anything to do with some -w option, rather "intel-win32" is split and "-win32" passed as an incorrect argument).
So, go to the the boost build engine directory e.g. D:\boost\boost_1_53_0\tools\build\v2\engine and execute the command without "-win32", first
and then
Both will hopefully succeed. Then go back to the root of your boost, e.g. D:\boost\boost_1_53_0 and copy and edit bootstrap.bat script. Comment out or delete first few lines including
call .\build.bat %* > ..\..\..\..\bootstrap.log @ECHO OFF
popd
and the execute the rest of the script.
Now you could run b2 to get the 32-bit boost, but if you want 64-bit version, execute something like this:
bjam.exe --prefix=d:\boost\intel toolset=intel-win32 address-model=64 variant=debug,release link=static,shared threading=multi install
which hopefully will succeed. d:\boost\intel in the example above is the dir where you want bjam to create inlude and lib directories - your new boost root.
Good luck,
Slawek
Ah, forgotten one point. Before final building, go to the compiler location, e.g. C:\Program Files (x86)\Intel\Composer XE 2013 SP1\bin and copy iclvars.bat into the intel64 subdirectory (I assume you want to get 64-bit version, did not test for 32-bit version of the Boost)
Good luck again,
Slawek
Thank you for posting these instructions. Helped me.
