icc 15.0.0 fails to compile the following
#include <utility> struct S { enum E {A,B}; // convert run-time variable e to a compile-time variable template<template<E> class F, typename... Args> static auto Switch(E e, Args&&... args) -> decltype(F<A>::act(std::forward<Args>(args)...)) { switch(e) { case A: return F<A>::act(std::forward<Args>(args)...); case B: return F<B>::act(std::forward<Args>(args)...); } } }; template<S::E> struct foo { static double act(double); }; double work(S::E e, double x) { return S::Switch<foo>(e,x); }
but fails with the error message "no instance of the function template "S::Switch" matches the argument list". This is obviously wrong.
Thanks for the test case. I can reproduce this error message with 15.0.2. This GNU compiler has no problem compiling this code. I'll update this thread with an internal tracking ID.
The internal tracking ID for this issue is DPD200366869.
I verified that this issue is fixed in the 16.0 Update 1 release, which will be available for download soon.
Topic Options
