Intel® C++ Compiler
7956 Discussions
failure to compile variadic template function
Walter_D_
icc 15.0.0 fails to compile the following
#include <utility>
struct S {
  enum E {A,B};
  // convert run-time variable e to a compile-time variable
  template<template<E> class F, typename... Args>
  static auto Switch(E e, Args&&... args)
    -> decltype(F<A>::act(std::forward<Args>(args)...))
    switch(e) {
    case A: return F<A>::act(std::forward<Args>(args)...);
    case B: return F<B>::act(std::forward<Args>(args)...);
template<S::E>
struct foo { static double act(double); };
double work(S::E e, double x)
{ return S::Switch<foo>(e,x); }
but fails with the error message "no instance of the function template "S::Switch" matches the argument list". This is obviously wrong.
Amanda_S_Intel
Thanks for the test case. I can reproduce this error message with 15.0.2. This GNU compiler has no problem compiling this code. I'll update this thread with an internal tracking ID.
Amanda_S_Intel
The internal tracking ID for this issue is DPD200366869.
Amanda_S_Intel
I verified that this issue is fixed in the 16.0 Update 1 release, which will be available for download soon.
