Community
cancel
Showing results for
Search instead for
Did you mean:
esouka
fatal error LNK1104: cannot open file 'ippi.h'
i am linking visual studio 2008 with intel ipp, i put the path to ipp include directory into visual studio at properties -> c/c++ -> general -> additional include directories, i did the same for linker -> general -> additional library directories, i also put active(intelIPP) instead of active(debug), the problem is that it doesn't find header files,
what can i do?
thank you
mecej4
Black Belt
I think that you have entered something incorrectly into your project options. The message
indicates that the linker is being asked to process a header file, which it cannot do. Header files are of use only at the compilation stage.
