Hi all
i am facing the following problem. I compiled my application whhich performs some complex dsp calculations
using the flags /O3 and /QxNP. The applications
avergae behavior has improved in terms of CPU utilization
by as much as 40 % but the peak behavior has still not improved . In fact i am getting the same peak cpu utilization as earlier but these peak cpu utilizations occur very frequently. Can anybody explain this.
thanks
Mayank
thanks
Mayank
Message Edited by mayank_kumarin on 07-01-2004 01:37 AM
One explanation is the most compute intensive part of your program has not been changed, so the peak stays the same. The rest have better performance with the optimizations causing average utilization up.
Peng.
