Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7699 Discussions
float _Complex fc = 1.5DF; => internal error in icc11.1
tydeman
Code similar to:
#define __STDC_WANT_DEC_FP__
static float _Complex fc = 1.5DF;
gets: internal error: assertion failed: type_change_constant: decimal_float to bad type ...
This is icc 11.1 in IA-32 mode on Linux Fedora Core 10 on Pentium 4 in IA-32 mode.
Milind_Kulkarni__Int
New Contributor II
Do you mean typecasting the Decimal32 to float _Complex. I don't think that would work.
This works though:--
//#define __STDC_WANT_DEC_FP__
static double _Complex fc = 1.5i;
_Decimal32 fc2=1.5DF;
Also, to work with Decimal types, I think .c extension (C-file) will only work.
tydeman
I mean that code as written. That is an assignment from _Decimal32 to
float _Complex. It is supposed to work. This is a *.c file.
New Contributor II
yes, you sound correct. gcc compilers starting from 4.3.x and onwards have that working. I have escalated this to the compiler team, to get it resolved.
