Intel® C++ Compiler
7956 Discussions
fmod(-2, 2) returns 0 instead of -0
Levi_Morrison
My understanding is that fmod(-2, 2) should return -0, not 0. With or without -fp-model strict I get positive 0. Is this a bug, or do I need to enable some other flag?
$ icc --version
icc (ICC) 13.0.1 20121010
Levi_Morrison
This seems ot have double-posted. Apologies.
SergeyKostrov
Valued Contributor II
You're right. ... _tprintf( _T("FMOD for FLOAT : % f\n"), ( float )fmodf( -2.0f, 2.0f ) ); _tprintf( _T("FMOD for DOUBLE: % f\n"), ( double )fmod( -2.0L, 2.0L ) ); ... [ Intel C++ compiler v12.1.3.300 & VS 2005 ] FMOD for FLOAT : -0.000000 FMOD for DOUBLE: -0.000000 [ Microsoft C++ compiler ( VS 2005 ) ] FMOD for FLOAT : -0.000000 FMOD for DOUBLE: -0.000000 [ Borland C++ compiler v5.5 ] FMOD for FLOAT : -0.000000 FMOD for DOUBLE: -0.000000 [ MinGW C++ compiler v3.4.2 ] Note: Wrong results as well FMOD for FLOAT : 0.000000 FMOD for DOUBLE: 0.000000
SergeyKostrov
>>My understanding is that fmod(-2, 2) should return -0, not 0... Update: - I couldn't reproduce the problem with Intel C++ compiler ( 13.0.089 / Initial Release ) on Windows 7 Professional OS ( in a 32-bit test application ) - In your example -2 and 2 are integers and these numbers are not floating-point data types - How did you compile a fmod( -2, 2 ) statement? There are 3 overloads for fmod CRT-function for float, double and long double floating-points data types and if I don't specify a data type Intel C++ compiler doesn't compile that statement - On Windows platforms fmod( -2.0L, 2.0L ) is called from Microsoft CRT library ( like, msvcrt.dll ) and if it has a problem ( let's assume it... ) it can't be related to Intel C++ compiler - Could you provide a complete test case with compiler command line options, please? - What is your platform? Linux or Windows? - If you're on Linux what libraries did you use?
Georg_Z_Intel
Hello, I can reproduce the problem on 64 bit -- 32 bit is working correctly. This is only visible if compiler optimizations make use of SVML. Hence, if you compile w/o (aggressive) optimizations and use libm.so manually, the system's implementation is used, producing correct results, e.g.: $ icc -lm fmod.c -O0 && ./a.out icc: warning #10315: specifying -lm before files may supercede the Intel(R) math library and affect performance [+] fmod(2, 2): 0.000000 [+] fmod(2, -2): 0.000000 [-] fmod(-2, 2): -0.000000 [-] fmod(-2, -2): -0.000000 I've filed a defect ticket for engineering (DPD200321811) and let you know once this is fixed. Best regards, Georg Zitzlsberger
SergeyKostrov
Hi Georg, >>...I can reproduce the problem on 64 bit ... Do you mean a 64-bit Linux platform?. >>...This is only visible if compiler optimizations make use of SVML... What other compiler options did you use to reproduce the problem? I see that you've used just -O0 in order to get the correct result: >>$ icc -lm fmod.c -O0 && ./a.out
Georg_Z_Intel
Hello Sergey, "icc"/"icpc" are the C/C++ compiler names for Linux*, "icl" for Windows*. So, yes, the problem was reproduced on a 64 bit Linux* platform. The problem is only not visible with optimizations using SVML being turned off (as it's the case for -O0 or -O1). Higher levels induce SVML. Best regards, Georg Zitzlsberger
Levi_Morrison
Is there some way I can track this issue somehow other than checking this thread for updates?
Georg_Z_Intel
Hello, you can subscribe to this thread and you'll get a notification with every new reply (including the one announcing a fix). Btw.: Notifications did not work in the past but are back again. Best regards, Georg Zitzlsberger
Georg_Z_Intel
Hello, engineering just reported that it has been fixed beginning with Intel(R) Composer XE 2013 Update 2. Best regards, Georg Zitzlsberger
SergeyKostrov
Thanks, Georg and I will do a quick verification. I regret that it is reported well after the Update 2 was released ( and Update 4 is about to be released... ).
SergeyKostrov
>>...engineering just reported that it has been fixed beginning with Intel(R) Composer XE 2013 Update 2... Here are test results with Intel C++ compiler v13.1.0.149 ( Update 2 ): *** Tests after FIX *** [ Intel C++ compiler v13.1.0.149 ( Update 2 ) Build 20130118 32-bit & VS 2008 ] FMOD for FLOAT : -0.000000 FMOD for DOUBLE: -0.000000 [ Intel C++ compiler v13.1.0.149 ( Update 2 ) Build 20130118 64-bit & VS 2008 ] FMOD for FLOAT : -0.000000 FMOD for DOUBLE: 0.000000 Note: Not Fixed [ Borland C++ compiler v5.5 ] FMOD for FLOAT : -0.000000 FMOD for DOUBLE: -0.000000 *** Old Tests with different C++ compilers *** [ Intel C++ compiler v12.1.3.300 & VS 2005 ] FMOD for FLOAT : -0.000000 FMOD for DOUBLE: -0.000000 [ Microsoft C++ compiler ( VS 2005 ) ] FMOD for FLOAT : -0.000000 FMOD for DOUBLE: -0.000000 [ Borland C++ compiler v5.5 ] FMOD for FLOAT : -0.000000 FMOD for DOUBLE: -0.000000 [ MinGW C++ compiler v3.4.2 ] Note: Wrong results as well FMOD for FLOAT : 0.000000 FMOD for DOUBLE: 0.000000
SergeyKostrov
Here is updated test case: // icl.exe /MD Test.cpp #define _UNICODE #include "stdio.h" #include "tchar.h" #include "math.h" int main( void ) { _tprintf( _T("FMOD for FLOAT : % f\n"), ( float )fmodf( -2.0f, 2.0f ) ); _tprintf( _T("FMOD for DOUBLE: % f\n"), ( double )fmod( -2.0L, 2.0L ) ); return ( int )0; }
