My understanding is that fmod(-2, 2) should return -0, not 0. With or without -fp-model strict I get positive 0. Is this a bug, or do I need to enable some other flag?
$ icc --version
icc (ICC) 13.0.1 20121010
This seems ot have double-posted. Apologies.
You're right.
_tprintf( _T("FMOD for FLOAT : % f\n"), ( float )fmodf( -2.0f, 2.0f ) );
_tprintf( _T("FMOD for DOUBLE: % f\n"), ( double )fmod( -2.0L, 2.0L ) );
[ Intel C++ compiler v12.1.3.300 & VS 2005 ]
FMOD for FLOAT : -0.000000
FMOD for DOUBLE: -0.000000
[ Microsoft C++ compiler ( VS 2005 ) ]
[ Borland C++ compiler v5.5 ]
[ MinGW C++ compiler v3.4.2 ] Note: Wrong results as well
FMOD for FLOAT : 0.000000
FMOD for DOUBLE: 0.000000
>>My understanding is that fmod(-2, 2) should return -0, not 0...
Update:
- I couldn't reproduce the problem with Intel C++ compiler ( 13.0.089 / Initial Release ) on Windows 7 Professional OS ( in a 32-bit test application )
- In your example -2 and 2 are integers and these numbers are not floating-point data types
- How did you compile a fmod( -2, 2 ) statement? There are 3 overloads for fmod CRT-function for float, double and long double floating-points data types and if I don't specify a data type Intel C++ compiler doesn't compile that statement
- On Windows platforms fmod( -2.0L, 2.0L ) is called from Microsoft CRT library ( like, msvcrt.dll ) and if it has a problem ( let's assume it... ) it can't be related to Intel C++ compiler
- Could you provide a complete test case with compiler command line options, please?
- What is your platform? Linux or Windows?
- If you're on Linux what libraries did you use?
I can reproduce the problem on 64 bit -- 32 bit is working correctly. This is only visible if compiler optimizations make use of SVML.
Hence, if you compile w/o (aggressive) optimizations and use libm.so manually, the system's implementation is used, producing correct results, e.g.:
$ icc -lm fmod.c -O0 && ./a.out
icc: warning #10315: specifying -lm before files may supercede the Intel(R) math library and affect performance
[+] fmod(2, 2): 0.000000
[+] fmod(2, -2): 0.000000
[-] fmod(-2, 2): -0.000000
[-] fmod(-2, -2): -0.000000
I've filed a defect ticket for engineering (DPD200321811) and let you know once this is fixed.
Georg Zitzlsberger
Hi Georg,
>>...I can reproduce the problem on 64 bit ...
Do you mean a 64-bit Linux platform?.
>>...This is only visible if compiler optimizations make use of SVML...
What other compiler options did you use to reproduce the problem? I see that you've used just -O0 in order to get the correct result:
Hello Sergey,
"icc"/"icpc" are the C/C++ compiler names for Linux*, "icl" for Windows*. So, yes, the problem was reproduced on a 64 bit Linux* platform.
The problem is only not visible with optimizations using SVML being turned off (as it's the case for -O0 or -O1). Higher levels induce SVML.
Georg Zitzlsberger
Is there some way I can track this issue somehow other than checking this thread for updates?
you can subscribe to this thread and you'll get a notification with every new reply (including the one announcing a fix).
Btw.: Notifications did not work in the past but are back again.
Georg Zitzlsberger
engineering just reported that it has been fixed beginning with Intel(R) Composer XE 2013 Update 2.
Georg Zitzlsberger
Thanks, Georg and I will do a quick verification. I regret that it is reported well after the Update 2 was released ( and Update 4 is about to be released... ).
>>...engineering just reported that it has been fixed beginning with Intel(R) Composer XE 2013 Update 2...
Here are test results with Intel C++ compiler v13.1.0.149 ( Update 2 ):
*** Tests after FIX ***
[ Intel C++ compiler v13.1.0.149 ( Update 2 ) Build 20130118 32-bit & VS 2008 ]
[ Intel C++ compiler v13.1.0.149 ( Update 2 ) Build 20130118 64-bit & VS 2008 ]
FMOD for DOUBLE: 0.000000 Note: Not Fixed
*** Old Tests with different C++ compilers ***
Here is updated test case:
// icl.exe /MD Test.cpp
#define _UNICODE
#include "stdio.h"
#include "tchar.h"
#include "math.h"
int main( void )
return ( int )0;
