Using the Intel C++ Compiler Professional for applications running on IA-32, Version 11.1, Build 20090511, I am encountering the for-scope error thus:
file.cpp(389): error: "i" has already been declared in the current scope
for (int i = 0; i < (foo->bar_count - 1); i += 2)
This should be acceptable with the ANSI standard, but nonetheless I am getting this error. If I recall correctly there is a compiler option that I can specify that will eliminate this error. However after browsing the Intel C++ compiler options via the website I still cannot find it.
Help?
Thanks!
Also I noticed that you're using an older 11.1, please upgrade to the latest 11.1.060 or at least 11.1.048. There is a bug in the original 11.1 release that will affect programs running on Windows 7.
Jennifer
Jennifer
Ok thank you so much for the reply. We'll look into the 11.1 bug, thanks for that heads up as well.
Is there a Linux/MacOS equivalent to the /Zc:forScope- option?
Thanks!
Jerry
There's no matching Linux option for /Zc:forScope-. But try followings:
'-c99' option on Linux
'-stdc99' option on Linux
'-stdc9x' option on Linux
About the bug in earlier 11.1 pkg, see this article about it:
- http://software.intel.com/en-us/articles/program-crashes-or-hangs-on-some-systems/
- http://software.intel.com/en-us/articles/the-installation-or-uninstallation-hangs-at-start-up-dialog...
Jennifer
{ // hack scope for Intel V11.0.0 bug
} // end hack scope for Intel V11.0.0 bug
