Community
cancel
Showing results for
Search instead for
Did you mean:
zvivered
gcc version for Intel Compiler 8.1
We installed 8.1 on Red Hat that has gcc 4.1.2
When icc was executed it returned an error: Invalid GNU version (412)
Why does icc cares what is the gcc version installed ?
We want to work with gcc 4.3.2 cross toolchain we built using crosstool-ng
This gcc was used to compile the linux kerenl (2.6.27.35) from kernel.org
How can we tell icc to work with our gcc and not the one installed on the red hat ?
Is there a limitation on the glibc version contained in the gcc ?
TimP
Black Belt
gcc 4.x certainly has some features which weren't supported by icc 8.1, particularly in C++.
With such an old version of icc, I believe you had to make the gcc you want active when installing icc (by putting it first on PATH) (unless you want to hack the configuration files). I would think the situations where you could use icc as a cross compiler would be extremely limited.
